![]() Join Date: Sep 2006
Ichiba vs Nissan rear hubs
This is a comparison between the Ichiba versus Nissan rear hubs for the 240SX. Check out this video and let me know what you think.
YouTube - Ichiba and Nissan 240SX rear hubs spline comparison Here's a couple of more videos I found. Similar problem that I had. Video speaks for itself. http://www.youtube.com/watch?v=lXXC84Gnhu0 http://www.youtube.com/watch?v=neklmdzDX-k Last edited by koukie180; 12-14-2009 at 06:10 PM.. Reason: Added a couple more videos |
#2 | |
![]() Join Date: Sep 2007
Trader Rating: (25)
Thank god, someone needed to finally make one of these. I'm just not sure if this is the right section. Good work.
![]() Join Date: Jun 2004
Trader Rating: (73)
I've never used Ichiba rears, but I do know that their front bearings are complete DOG SHIT.
I've had over 3 pairs of the fronts and my friend's have used 2 sets as well. After my first set's bearings FELL OUT upon removal for inspection, I warrantied them only to get another set that had bearings that made progressively worse road noise after less than 1500 miles. After that crap I pressed in my old 2193871298732+ mile bearings from my old OEM hubs (because I was broke) and that totally fixed my problem. After that I bought another set of used ones and pressed in new OEM bearings and that solved my issue. After watching the video of the rear hubs though... that's fucking sad. I will never buy a car with REAR Ichiba. IMO there's no real reason to, because the NA 300zx and S14 SE hubs are direct bolt on and are relatively easy to find.
#10 | |
![]() Join Date: Feb 2006
Trader Rating: (47)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 47 reviews
Might be a bad batch due whatever circumstances. Just hit up Ichiba, they have a one year warranty last time I checked when I used to sell them. Good luck. |
#11 | |
Trader Rating: (73)
This thread is almost a years old.
Hmmm... from what I can see, those with problems have problems getting their parts warrantied.
![]() Join Date: Apr 2009
Trader Rating: (46)
![]() Feedback Score: 46 reviews
well if you mention to ray you're a zilvia member he can work w/u on price...he did for me at least. got the fronts for about 200 bucks. not bad for brand new oe hubs if you ask me...especially since the ebay versions are around 160.
#17 |
#20 | |
However when you push out the old bearings from a hub, it normally destroys them. |
#21 |
Trader Rating: (73)
It just worked. I didn't know that happened with these bearings because it's never happened to me and I've done it like 3 or 4 times.
#22 |
![]() Join Date: Mar 2008
Trader Rating: (81)
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 81 reviews
i've had clunking noise comming from a customers ichiba hub, but after taking it off to inspect and putting it back on, it went away. weird. can't beat the price but if you have the money, go OEM.
http://squarespokes.com/ |
#23 |
![]() Join Date: Dec 2002
Never seen a destroyed bearing by pressing it out. The outer race usually pops off and stays seated on the hub, just use a bearing splitter to remove it, then press it back on the bearing. No harm done.
#24 |
![]() Join Date: Apr 2003
Trader Rating: (32)
![]() Feedback Score: 32 reviews
Front Ichiba hubs I purchased didnt "bolt on" at all. Far from it. Snap ring was incorrect (swapped with OEM ring), bearing seal not pressed in all the way. Not impressed.
2018 Audi RS 3 | Unitronic Stage 1 ECU and Stage 2 TCU tune |
