hey i am ready to start my rb swap into my 97 240 and i was wondering if anyone would be able to give me a list of things im going to need im going to put a rb25 out of a r33 im planning on buying an entire front clip and now i am just wondering what im going to need to get it in and runnin reliably so if anyone could give me a hand it would be greatly appreciated
I used the McKinney mounts with my swap, I thought it went in pretty easily. Probably the biggest problem you will run into is the wiring... I just paid to have mine modded for PNP. You can pm me if you want to pick my brain for any questions.
lol start with mounts then (i say syko performance) then u will need a r33 crossmember to bolt these mounts up 2. next thing would be custom intercooler piping i think phase2 makes a kit next would be wiring which syko does, next we move onto the driveshaft that phase2 has for sale. after that u should be plug and play make sure u get a better clutch change the water pump and belts. u should be good thats with and rb25 NOT 26
oh i forgot the radiator and fans u should be good with the stock radiator u need 2 12 inch slim fans u will have to make custom radiator hoses i believe |
![]() Join Date: Sep 2005
Be ready to hit your firewall with a BFH... cooling is gonna suck get push-fans and rad. Do your research, it's not hard but it's not easy. |
