If this thread needs to be move,let me know and do it.I feel like this is the best place though. I want to show my 240sx from when I first got it to all the modifications it has gone through. I will post problems I run into and how I solved them so the next person does not have the same problem
Info:1995 Nissan 240sx SE 121XXX Miles What it had:bad oil leak,ngk spark plug wires,lightweight flywheel,ebay stage 2 clutch,window tint everything except windshield,couple cracks in the windshield,ebay short shifter,hid's How the car was when I got it: Had the maintenance done on it,leaks are fixed and car is running great. First thing to go was the exhaust: (for sale) HKS Hi-power exhaust ran the crap out of my tires and this is what happened,got 4 brand new fuzion vri's rockford fosgate wiring kit and amp,12" apline type r,and a custom box my friend built for me got 123456 miles on my car(second car to do it in) had the chips in the windshield fixed by some random guy at a gas station for $20,sketchy as no other but did a good job driver side window amp went bad,bought a whole used door and replaced it push button start installed car started acting up and revved between 0 and 2k rpms,wouldnt rev above 5k,ran really rich. MAF CEL code came on,replaced the sensor and it did not fixed,turns out it was the wiring,went through it to see where it was bad,replaced some of it and the problem was solved.I need to solder them to make it a permanent fix ISIS coilovers-some say bad things about them but they ride pretty good,installed them wrong with the preload or whatever and Im working on fixing that problem camber from lowering the car was great, so i purchased godspeed rear upper control arms(RUCA's) and installed them thought the bolt was too short but it just needed to be tightened and everything turned out great bolt i thought was too short the old camber arms carbon fiber roof wing(used + bad idea) but looks decent,double sided tape is alright i guess to be installed: tanabe front sway bar painted valve cover random pics |
