Old 01-16-2007, 04:15 PM   #1
shadohconspiracy
shadohconspiracy will become famous soon enoughshadohconspiracy will become famous soon enoughshadohconspiracy will become famous soon enough
Clutch Pedal is really loose... HELP!
Today it is snowing and being the kid that i am , i was just so excited that even if i couldnt drive the car right now, i'd decide to sit in it and juss check out how everything works.
Ok so heres the story. I was just messing around with the radio and stuff and was adjusting everything (seat postion, mirrors , etc.) then i was practicing with the shifter , to get a better feel of the gears. Anyways so i was pressing my clutch and stuff and all of a sudden CLUNK , i found out that i didnt push the seat to a locking position so i pushed on the clutch pedal really hard, and now its feeling really loose , like there is no rebound . SOMEONE PLEASE HELP!! I hope its just something simple. SORRY FOR THE LONG POST , Thanks
shadohconspiracy is offline   Reply With Quote
Old 01-16-2007, 04:18 PM   #2
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
lmao.
stop being 12 years old.
umm did u like open the hood and look for brake fluid or get under the car and check anything? do that
lol nice rep
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 01-16-2007, 04:23 PM   #3
shadohconspiracy
i opened the hood and i checked the this cylinder on the far left side , close to the drivers fenders. The fluid in there is all the way to the top. when i get under the car what do i look for?
Old 01-16-2007, 04:26 PM   #4
djkowai
djkowai will become famous soon enoughdjkowai will become famous soon enoughdjkowai will become famous soon enoughdjkowai will become famous soon enough
you look on the transmission at the clutch slave cylinder, if somethings wrong it should be leaking on the ground.
djkowai is offline   Reply With Quote
Old 01-16-2007, 04:36 PM   #5
shadohconspiracy
ok , from waht im seeing on the ground it seems to have a just a little oil on the floor from the oil pan and thers this other little driplet onto the left side of the car... but its not close to the transmission
Old 01-16-2007, 04:42 PM   #6
ALTRNTV
Bleed your clutch, there's probably air in your system.
Old 01-16-2007, 04:46 PM   #7
shadohconspiracy
hmm... do you think that opening the cap on the cylinder let the air in?
Old 01-16-2007, 04:47 PM   #8
ALTRNTV
No, that has nothing to do with letting the air in. Unless there was no fluid in it to begin with, then pouring clutch fluid, that could let air in.
Old 01-16-2007, 04:52 PM   #9
shadohconspiracy
so air just got in by itself?? strange....
Old 01-16-2007, 04:52 PM   #10
steve shadows
steve shadows's Avatar
steve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfection
Send a message via AIM to steve shadows
cut your foot off and then you wont feel how loose it is.
Coderize for a nice suprise for the ladies (quagmire voice) oh!
Could be the bolt adjustment under the dash, you can tighter or loosen it.
or....
I actually had one break off the fire wall, like the welds to the bracket in the car.
I had to remove the dash and custom rig a hole drill through the firewall with a lock nut and two washers so I could make ti back to a race the next day.
woo!
heavy foot
Like Me on FaceBook !
steve shadows is offline   Reply With Quote
Old 01-16-2007, 04:54 PM   #11
ALTRNTV
You could have a faulty clutch master cylinder and/or slave cylinder.
Old 01-16-2007, 04:56 PM   #12
shadohconspiracy
so does that mean i need a new one, or bleeding it should solve the problem?
Old 01-16-2007, 04:59 PM   #13
ALTRNTV
Do the simple thing first: bleed your system.
Old 01-16-2007, 05:00 PM   #14
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
well bleeding it will tell you if you need a new one... So bleed it, then if it doesnt fix it then replace
Slip Gypsies Blog
not sure if you realize this
Old 01-16-2007, 05:04 PM   #15
shadohconspiracy
ok thanks for all the help guys , but this is when i start being really newb. So like i get a friend to depress/release teh clutch while i am opening and closing the bleeding valve right?
Old 01-16-2007, 05:09 PM   #16
ALTRNTV
First off, remove the dampener box. It's a pain in the ass to bleed when it's connected.
http://www.zeroyon.com/index/content/view/32/47/
Bleeding the system:
-fill clutch reservoir with DOT 3 brake fluid
-have someone pump the pedal 3 times, then hold
-release the bleeder valve on the clutch cylinder and wait til the air/fluid leak out
-tighten screw
-pump 3 times again, then hold
-release bleeder screw, repeat process until clutch pedal feels firm (don't forget to watch the reservoir, fill it up when low, don't let it get too low, since air will just go back in)
Old 01-16-2007, 05:13 PM   #17
shadohconspiracy
thanks a lot akademik , do you think it will still pump fine if my pedal is all loose as i stated?
Old 01-16-2007, 05:17 PM   #18
ALTRNTV
Tighten your pedal then. Not that hard. lol
Old 01-16-2007, 05:18 PM   #19
shadohconspiracy
what do you mean tighten my pedal? i think the main problem right now is that i have no resistance on the pedal, and i am trying to fix it by asking all these questions
Old 01-16-2007, 05:22 PM   #20
ALTRNTV
Now I'm confused. Is your pedal loose? Or is your pedal not going back up when you press it?
Old 01-16-2007, 05:26 PM   #21
LB.Motoring
LB.Motoring's Avatar
a buddy broke the tack welds on his clutch pedal and it had the same problem(wont come back up, SLightly cockeyed). I took it off redrilled the tack weld and bolted it.
Robby Leuer
Old 01-16-2007, 05:48 PM   #22
shadohconspiracy
the pedal does come back up , but tehres no response like you normally will get on a normally operating clutch
Old 01-16-2007, 05:51 PM   #23
ALTRNTV
What you mean "no response?" If it comes straight back up, then I think the clutch is fine, and there's no air in the system?
Old 01-16-2007, 05:57 PM   #24
shadohconspiracy
it does com straight back up but that is only pulled by the spring on the pedal assembly, you dont have the normal response as if your clutch is actually working.... i am having an headache
Old 01-16-2007, 05:59 PM   #25
ALTRNTV
Let's start off with:
1)Do you feel any pressure when you press the pedal?
Old 01-16-2007, 06:05 PM   #26
shadohconspiracy
yes , minimal pressure not as much as before
Old 01-16-2007, 06:06 PM   #27
ALTRNTV
Bleed your system.
Old 01-16-2007, 06:08 PM   #28
shadohconspiracy
when the clutch is depressed , i cant get into gears but i can start the car
Old 01-16-2007, 06:11 PM   #29
shadohconspiracy
do you have a picture of where the location of the bleeder valve is thanks
Old 01-16-2007, 06:12 PM   #30
ALTRNTV
When you press the clutch (regardless of it working or not), it activates a switch so you can start the car. If you can't get into any gears, then your clutch system has air in it. Bleeeeeeeeeed.
Get under your car. Look for the transmission. Look for the soft clutch line. That line is connected to the slave cylinder. You'll see a valve there, use a 10mm socket to loosen and tighten it.
Wow, I'm being so nice today. I should flame you since this info can be found by SEARCHING. Hahahahaha
