Hey guys whats up, Ive been searching around and really cant get a down right answer. My new car that I picked up which is a 91 has a pretty loud ticking noise and it sounds like its right under the valve cover. So I did what everybody said to do and checked the upper timing chain guide and that looks like its been removed already. So I checked cams and it seems like the cams aren't really oiled but I've never really taken a valve cover off before so I'm not sure how wet they are supposed to be. The oil stupid light is on and stays on and the whole underbody of this car has oil everywhere but the oil is at the full mark. If someone can steer me in the right direction. Also the guy I got it from said he did the 2 exhaust cams upgrade or whatever it is. Sorry that Im a noob but you gotta learn somewhere lol. Thanks Guys
![]() Join Date: Sep 2012
its probably your timing chain knocking against the cover.. when you took the valve cover off did you notice any scarring on the underside where the chain would be at? if so youll need a new one you can get at frsport or the nismoshop. it could also be your water pump(the same thing happened to my engine and it ended up needing a new water pump and the sound vanished after it was installed. lol as for the oil everywhere its not uncommon for a 20 year old car to have grease and oil all around the engine bay unless its been babied and very well taken care of if, the oil seems quite fresh and new you might have a engine seal thats bad... well thats my take on things hope it helps a bit
#3 | |
Ok one more question, so I think that this motor might have more problems then I thought. I took off the oil filter and there was no oil in the thing. So I started the bitch up without one on there and had my dad looking to see if there was any oil. Nothing came out with the filter off. Well do I get a new oil pump or just worry about it when I get back. Again my dad is going to have to move it time to time like a few feet.
![]() Join Date: May 2008
Trader Rating: (26)
Take a video if you can. When my Ka starting making noises it was because I slipped a connecting rod bearing. If your oil pump or the pickup isnt working properly, the motor have have oil starvation and that would cause your knocking sounds.
And drift im gonna say 99% its timing chain noise. The body is in good condition so if I have to just ditch the motor and do another KA im fine with that. I dont want to do the normal SR swap. So a turbo ka in the future for sure. Thanks guys for the info and not bashing my "noobiness" lol. |
![]() Join Date: Feb 2006
I had a similar issue on mine.. Noise was my timing chain tensioner went out.....The lack of oil pressure can point at the oil pump, or if someone has been into the motor and didn't put the seal back between the lower cover and block you would be losing pressure there. I didn't replace the seal on mine(i know dumb move) and I had 0 oil pressure when I went to start the motor.. Replaced that seal and have great oil pressure. I wouldn't risk starting it up too many more times if you're saying you have 0 oil pressure. you may damage it beyond repair, unless you just intend to source another KA when you return. Be safe on your deployment!
#9 | |
![]() Join Date: Dec 2012
i had a knocking motor once... drove down the road and floored it. threw the rod then drove home on 3 cyl and no oil with a piston hanging out. broke the girdle too.
then 5 months later motor was knocking and then seized. but it was knocking for a month or so |
