![]() Join Date: Mar 2008
Trader Rating: (36)
![]() Feedback Score: 36 reviews
*SoCal* HKS, PBM, APEX’I, 5 lug, seats, spacers, wildwood BBK – All priced to sell!!!
My entire spare bedroom is filled with car parts that I don’t need anymore and the wifey is getting irritated so this stuff has to go. I’m okay with shipping anything at buyer’s expense with the exception of the seats. First person to pay gets the item and everything is priced to sell so act fast. I am located in Fullerton, CA and I accept paypal and cash only.
If you are going to offer a trade I will only accept z32 front calipers (30mm & aluminum), 4.36 final drive (ring gear & pinion at a minimum), koni suspension setup, z32 rear uprights, or sway bars. 1. S13 SR20DET Oil pressure switch ( 1/8” BSPT) Brand new $10 (2 available) 2. Complete plug and play harness for S13 SR20DET into S13 chassis. It has all connections minus cruise control, and power steering sensor. Sold as-is. The unwrapped portion of the harness is on the side of the cabin and has a plastic guide/support with it.- $125 SOLD 3. S13 SR20DET Mass Airflow Sensor MAF. It is used but fully functional. - $40 4. S13 SR20DET Air intake system. This includes a S13 SR20DET MAF adapter with 3” to 4” reducer coupler with 100mm inlet HKS honeycomb air intake filter. The whole thing is a 100% bolt-on affair. The adapter is constructed of lightweight aluminum, the vibrant red coupler reducer was purchased from Autobacs (not fleabay) and the air intake is a legitimate HKS unit. Obviously, the filter is used and dirty but replacements are only 20 dollars online. Comes with free hose clamps - $55 5. S13 SR20DET idle air control valve (IACV). I bought theses on the forum but never needed them in the end. I was told they were in working order but never installed them. Sold as-is. - $40 (1 left) (First unit sold gets a free IACV gasket free) 6. E5 ECU. I used this ECU which came with my redtop for 2.5 years with no problem. I’m currently running an Enthalpy tuned 62 ECU (GT28R, 550cc injectors, z32 maf) and when I reconnected the E5 ECU the car ran rough. I have no idea nor do I have any interest in investigating this so I’m selling it as-is. - $45 SOLD 7. APEX’i intake filter adapter BRAND NEW (adapter only). This unit bolts up directly to any of the APEX’i filters. The downstream end easily slips right in to any 3” (75-80mm) coupler. Presto! - $20 SOLD 8. JDM oil cap for S13 SR20DET. It came with my motor and I’m pretty sure it fits several other motors but I’ll leave you to do the homework here. – FREE WITH ANY PURCHASE OVER $30 9. S13 DUAL-diaphragm Brake Booster new. This new brake booster is with 0 miles and all the ticketing, original receipt included. The exterior has a few oxidation spots from being stored in a tool shed. Do you have a z32 brake setup? Don’t bother trying to cut-out your firewall just to get a z32 brake booster installed. This brake booster can get the job done just as well with no modifications necessary. It’s a 100% bolt-on affair for your S13. The Dual diaphragm brake booster is also ideal for the SR20DET or any turbo setup because of their inherent trait to produce less vacuum than their naturally aspirated counterparts. - $110 SOLD 10. Hub centric Wheel spacers. I have four pairs. Bolt pattern 4x114. Thread pitch 1.25 a. 25mm Powered By Max PBM bolt-on spacers with hub centric rings - $60 SOLD b. 20mm Powered By Max PBM bolt-on spacers with hub centric rings - $55 SOLD c. 15mm H&R slip-on wheel spacers with hub centric rings - $60 SOLD d. 10mm H&R slip-on wheel spacers with hub centric rings - $55 SOLD 11. C-pillar bar for s13 Hatch. Not sure if it will work on the coupe. It doesn’t have some adjustability in length. Allows for the user to retain rear seatbelts in full working order and if an opening is made on the stock seat belt mechanism covers, they can be retained too (see pics) - $10 SOLD 12. Passenger side headlight assembly with headlight cover (painted black) - $50 13. Driver side headlight covers painted black - $15 (2 available) 14. Powered By Max PBM subframe spacers for S13. Designed for taking out the slop and increasing response from subframes with OEM rubber or polyurethane bushings (e.g. Energy Bushings). - $30 SOLD 15. S14 5 lug hubs with spindles. Don’t settle for china-made bearings that come with aftermarket hubs. These are tried and proven OEM bearings. Also comes with extended studs all around and splash shield. Splash shields are already nicely trimmed for you fellas with big brakes - $140 SOLD 16. 5 lug hubs for S13. I bought these hubs for my S13 from tokona-x here on zilvia who modified them in an undisclosed manner. Unfortunately, from day 1 they made a lot of noise at high speeds and I think bearings are bad so I’m selling them cheap. Sold as is. Install new bearings in these inexpensive OEM units instead of buying expensive Ichiba or Attain units since the china-bearings should be replaced with OEM bearings anyways. - $30 SOLD 17. Hood spacers (not really). They are the end pieces from an SPL traction rod, but they’re 100 times more visually appealing than home depot washers. - $5 SOLD 18. Wilwood Big Brake Kit. This Arizona Z Car brake kit will bolt right on to your 4 lugged S13 or S14. It comes with brake lines, calipers, adapter brackets, hats, rotors, and brake pads. Everything is fully functional. Wilwood Ultralite curved-vane rotors still have some life left. Rotor dimensions: 12.19x1.25" (310mm x 31.75mm). Calipers are 4 piston Wilwood Forged Dynalite calipers and are feather light. They are an excellent upgrade for dropping crucial unsprung weight and increasing road response. Rotor hats and caliper brackets are anodized red and they're exhibiting slight color fade. Stainless steel braided lines, and used Wilwood pads are also included. This setup was never driven on the track, just a few cautious canyon runs. Sold as-is. Price drop - [strike]$525[/strike] $440 SOLD 19. Bride Gias STYLE bucket seats with wedge engineering seat brackets. They are reclinable and they have rails for sliding too. They are about 1 year old and the passenger seat just got put in a few months ago. 100% bolt-in affair for S13, S14, and S15. Good condition. They are tight in size and they should be able to old riders up to 36" in waist I think.- $550 SOLD
![]() Join Date: May 2011
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
and need harness so i wont have to place anything in the harness for sr cause been doing my swap and been having wiring problems but if that one pluggs right in all around all pull mine and buy that also lmk about seats and harness pm me
#18 | |
Trader Rating: (36)
I replied to your PMs but I think this got left out. Sry
#19 |
Trader Rating: (36)
I'm willing to separate if I get payment for each seat from both parties. I'll leave it to the buyers to get coordinated. Seats are getting a lot of interest!
