1971 Datsun 240z RB25det Project 10k
I have my project up for sale. I don't have time to finish it so it's better suited for someone else to finish.
Currently trying to sell it all together for $10k. If it doesn't sell for some time i will part out. Pictures are located here: http://s66.photobucket.com/user/gree...5det%20Project If you are serious and want more pictures don't hesitate to IM me. Over the last 4 years the following was done: Powertrain RB25det series II out of R33 Gts-t - New gaskets throughout - New timing belt and water pump - Cylinder Head Rebuilt by Master Tech due to low compression when received from JDM Importer - ACL Connecting Rod bearings installed - Valve covers and timing cover proffesionally painted metalic blue - Freddy Intake manifold - Q45 Throttle Body - Top feed fuel rail - Evo 8 510cc/min injectors - Aeromotive adjustable fuel regulator & pressure gauge - Custom Made Baffled & Piano Hinged Rear Sump Oil Pan - GREDDY Remote Oil Cooler adapter - Remote 5"x10" Summit Oil Cooler - -10 Parker Push Lok Oil Lines with fittings to connect the cooler - Factory Divided exhaust maninfold Cerami-coated flat black good to 2500F - PureTurbos Billet Upgraded factory turbo http://www.pureturbo...rade-turbo.html - HKS SSQ Blow-Off-Recirc Valve - Oil and Water stainless line kit - Ebay Dump Pipe - Frozen Boost Air/Air Intercooler - Some piping and couplers - PRC Racing Aluminum Radiator with the appropriate sized inlets and outlets for RB25det - Innovate LC-1 Wideband with bosch O2 sensor - Wolf Motorsports V500 standalone ECU with RB25det plug and play adapter - Modified Stock Harness available - Mckinney motorsports Engine Mounts - New NGK Platinum plugs - Engine Idled on the Wolf Ecu to verify wiring and ECU integration - FUEL SAFE fuel cell - Walboro 225 fuel pump with 100 micron pre filter and 40 micron post filter. - Fuel plumbed with -10 pump inlet pushlok hose, outlet to engine is -8 pushlok hose and 3/8" stainless tubing with swagelok connections RB25det RWD 5-speed transmission - stock clutch - stock flywheel - no trans mount No Driveshaft - Will supply a 240z driveshaft and a RB25det transmission yoke R180 Open Differential - 3.7 Gear Ratio - Rebuilt with new seals and AMS oil synthetic gear oil - RT Mount Factory Halfshafts (4 pairs) Suspension Front - TechnoToyTunning Bolt-IN Camber Plates - GroundControl Style Coilovers - Non-Sectioned Struts - New Koyo Wheel bearings - New extended wheel studs - Rebuilt Steering Rack - Energy Suspension Bushings control arm and tension arm - Powdercoated front crossmember - Front Control Arms POR-15 coated - MOOG Ball Joints - MOOG Tie Rod End - Poly Steering Rack Mounts - Stagg strut inserts - New Poly swaybar bushings - Stock 240z Swaybar Rear - TechnoToyTunning Bolt-IN Camber Plates - GroundControl Style Coilovers - Non-Sectioned Struts - New Koyo Wheel bearings - New extended wheel studs - Arizona Z car Tubular Control Arms - Energy Suspension Bushings - Stagg strut inserts - New Poly swaybar bushings - Stock Fairlady Z Swaybar ('74) - Powdercoated brackets and crossmember for the rear - POR-15 coated diff mustache bar with poly bushings Brakes Front - Toyota 4x4 wented calipers - Calipers painted gold with G2 caliper paint - 300zx Rotors, had these turned but there is surface rust due to the car sitting - EBC green stuff pads - used but plenty of meat left - All new stainless lines up to the master cylinder - Stock proportioning valve Rear - Maxima Rear Disc Conversion - Rotors turned be there is some surface rust due to the car sitting - Calipers painted gold with G2 caliper paint - All new stainless lines up to the master cylinder Wheels/Tires -Rota RKR 15x8 -Ohtsu 215/60/15 (cheap tires to roll car around, 0 miles) Chassis - Rust free 1971 chassis with clean Michigan title - Series II ... has toolbox cubies - All tar and sound deadening removed from the underside and interior - Rear of chassis reinforced for fuel cell installation - Bad dog rails and subframe connectors installed - Shaved side markers and gas door - 4 point rollbar welded in to the rear - Rear Strut tower brace welded in - Front Strut towers re-inforced to the firewall - Front sway bar mounts re-inforced through the frame rail - Custom Seat Mount crossmember (passenger and driver side) - Bottom of chassis undercoated with POR-15 and finished coated with RustOleum Professional Flat black Body Doors - Early '70 door shells, red, minimal rust overall good shape - Another set of Series one doors, white, complete but show sings of previous poor rust repair(bubbles) Fenders - Series 1 fenders but later headlight buckets (steel) white no rust Hatch - Series 1 hatch, sandblasted and primered, not perfect Glass - all glass is included with the exception of windshield Air Dam - MSA Series 1 style fiberglass air dam Grill - Fairlady Z ('74) Front Grill Good shape Cowl Panels multiple Stock Front Valance pieces center and sides ok conditions 2 sets of inspection lids Interior - Early Series 1 dash with half cap - Ebay Recaro Fixed Bucket Seats Hard mounted - Peyton 3 spoke steering wheel with adapter - 240z door panels ok shape - Some other panels also available. Have a box full Gauges - Speedhut Revolution Tach with integrated shift light - Autometer SportComp Mechanical Oil Pressure Gauge full sweep - Autometer SportComp Water Temp Gauge full sweep - Autometer SportComp Boost Gauge full sweep Ligths -Fairlady Z front indicators (split housing) amber lens -Fairlady Z tail lights (assembly required) -Hella H4 Headlamps Wiring - Custom Engine Harness - not professional - Custom Body Harness - probably needs to be redone Last edited by theczechone; 06-28-2016 at 11:52 AM.. |
| 240z, fairlady, rb25det, s30 |
