speed sensor wire
in the connector down of fuse box (2 connector) witch one have the speed sensor wire in it.. and in this connector what is the color of the wire
and second question : in the speed sensor.. we got 2 pin .. 1 for B+ and the other one is for signal ? |
![]() Join Date: May 2003
Trader Rating: (43)
![]() Feedback Score: 43 reviews
I just hooked up my speed sensor wire as the previous owner never had it hooked up. I don't know what your setup is, but on my S14 with blacktop SR, the speed sensor wire is in E202 in the FSM. E202 is the 8 pin plug and it has the two wires from the speed sensor, red/yellow and red. In other words, both wires from the speed sensor go to E202. The female plug E19 then connects to E202 and feeds the speed signal to your instrument cluster.
I hope that helps. Ryan Ryan |
yeah you help me thanks ![]() |
