![]() Join Date: Sep 2009
GTO 5 Lug what bearings?
I need to replace a wheel bearing and my friend who sold me the car said he did the GTO hubs with bearings. Does anyone know which wheel bearing I need? Maybe s14?
GTO might be the brand of hubs he used.....
S14 bearing is integrated into the hub so you need to get them as 1 piece. If you have S14 front knuckles you will need S14 front hubs. |
![]() Join Date: Jan 2004
what knuckles do you have? were they swapped?
best bet is whatever knuckles you have, the bearings will match. ex. my front 5lug conversion hubs made by "s5" fit my s13 knuckles... and they use factory s13 bearings. it will be important for you to tell us whether you are talking about the front or rear hubs. front - you can replace just the bearings. rear - you typically buy new hubs. |
#6 | |
Nissan 240SX Performance Modification/4 lug to 5 lug conversion - Wikibooks, open books for an open world FS: GTO S13 Front 5 Lug Adaptor - S-Chassis.com I just need to swap out the front wheel bearing. |
