Power Window Stopped working S13
Hi, after a paintjob my Driver and Passenger powerwindow stopped working.
I swapped the fuse(30amp) but no dice, i tested the wires if any power is getting through to the switch. No power. Swapped Amp, no dice The switch doesnt even click Window motor works if i apply straight power to the motor tho. now im lost to what to do, is there a circuit breaker somewhere? i see on some diagram theres one. Maybe thats the cause? need some guidance? ?_? thankyou |
