![]() Join Date: Mar 2009
SOHC misfire issue
Alright so I've got a A/T SOHC S13 and after the car has been sitting for awhile (around 5 hours) if you get in and start it you have to give it gas or it stalls. It also has a misfire in drive at idle if you put the car in park or neutral it seems to mostly go away. The car has these new parts
-fuel filter -wires -cap -plugs -rotor -PCV valve -O2 sensor -fresh oil and air filter I also ran some injector cleaner though it to see if that would help but no luck. Has anybody had the same issue? I'm thinking of trying a fuel pump and maf next but I don't want to waste my money cause I'm broke as shit. ![]() |
![]() Join Date: Sep 2009
Have you tried the temp.sensor for the ECU? Like $18 at Autozone. Mine was the exact same symptoms then gradually got worse until it started dying on me. It would start after 5 minutes of cooling down though. Auto SOHC also. Your MAF might also be dirty.
