![]() Join Date: Sep 2009
S13 bmc
i've been reading for a while now and need inputs from the zilvian gurus..
I need a new BMC, the pression wont get to the rear brakes, my mechinic said I need a new BMC.. My car is RHD and no ABS, from what I've read, you cant use 240sx MBC because they're side specific... Which one should I get? S13? Z32? 240? (maybe I got the wrong information) Thanks guys! |
![]() Join Date: Dec 2006
if you want a direct replacement, then you need to order the J-Spec BMC unless you wanna rebuild it which you could probably do if you found a rebuild kit with the same bore and seals as the original
