![]() Join Date: May 2013
Quick timing question
Ok so I pulled my valve cover off to do my timing. I have the crank pulley notch lined up but the exhaust cam gear notch does not go to the one o'clock position with the other one at the 11.
![]() Join Date: Sep 2005
That's because you're a tooth off on the exhaust side!
11 links dot too dot, count them, fix it, set the ignition timing, done!
Keep engine at TDC.
Ziptie the intake cam too chain, remove tensioner, and CAS. Follow Fsm for loosening sequence on exhaust cam, rotate cam 1 toof. Don't really know if that would be the easiest way, but it's an easy job.
My thoughts exactly. Follow the process explained above
@UpshiftEngineering |
Ran like complete crap. Idle was terrible, fuel cuts while driving, wanted to die. I put it all back together, started it up (started right up), idle was good but at times went lean. Unfortunately I wasn't able to drive it because the valve cover gasket decided to crack in the rear and leak a ton of oil.
I will be updating you guys once my gasket comes in and my Tial wastegate also. My current wastegate is cheap and a ton of exhaust comes out the screamer pipe. |
![]() Join Date: Dec 2004
Trader Rating: (58)
One tooth off with CAS adjustment can get you somewhat close enough to run 'ok' for a bit...however it won't drive normally.
I had one that came in on tme that was a tooth off...boy she spooled fast with the cranked timing, but it fell over so flat!
Started it up today. Car ran much much better. Still waiting on my Tial wastegate so my current wastegate is leaking.
One problem though.... My vacuum is crazy high. It's reading 25 on my gauge. |
