08-12-2014, 08:59 PM | #1 |
Nardi classic won't fit my nrg quick release
Recently bought a slim hub and quick release from
NRg and I bought a nardi classic 340mm black steering wheel for my 1990 240sx hatch when I got all my stuff mounted and ready to go I whent to bolt on my classic and noticed only one hole would line up at a time is there a adapter or something else like mounting it to the hub |
08-12-2014, 09:02 PM | #2 |
You sure you lined up the hub correctly? Did you try rotating the quick release so its straight? Should have no issues lining up a NRG QR and Nardi wheel.
08-12-2014, 09:30 PM | #4 |
I had a similar issue. My Nardi wouldn't bolt onto my NRG hub. I found out that the hub I had had the bolt pattern for a Momo wheel. I found an adapter on eBay for cheap that fixed the issue.
08-12-2014, 10:17 PM | #5 |
If its a NRG 2.0 or higher quick release it will fit ANY 6 bolt pattern steering wheel. That is why there are soo many holes on the quick release. If you are running JUST the NRG hub, then you will need an adapter since the NRG hub only accepts Momo pcd spacing.
08-12-2014, 11:09 PM | #6 |
nrg slim works
http://cdn.mkimg.carview.co.jp/minka...6873c0e347.jpg
Keep it Classy |
08-22-2014, 09:57 PM | #8 | |
