Fabrication and DIY - Build your own exhaust, intake or piping
Hi guys! We have plenty of fabrication and DIY parts in stock and ready to go.
![]() 180 deg. Aluminum U-Bends ![]() 45 deg. Aluminum Elbows ![]() 90 deg. Aluminum Elbows ![]() Aluminum Straight Tubing ![]() Tight Radius Cast Aluminum Elbows ![]() 2-Bolt Exhaust Flanges ![]() 3-Bolt Exhaust Flanges ![]() 2-Bolt Exhaust Gaskets ![]() 3-Bolt Exhaust Gaskets ![]() Oil System Fittings ![]() Sensor Fitting and Bungs ![]() Aluminum Vacuum Fittings ![]() Velocity Stacks and Bellmouth Velocity Stack ![]() V-Band Flanges/Clamps ![]() 2-1 Merge Collectors]Merge Collectors ![]() Turbo Manifold Merge Collectors ![]() Steel Tubing and Piping ![]() Vibrant Ultra Quiet Resonators ![]() Bottle Style Resonators ![]() Flat Black Mufflers ![]() Large selection of Mufflers |
We lowered the price on what we could before we posted, hope the prices work for you... thanks for looking!
I'm not sure, but this is a good question. Vibrant doesn't say what kind of piping this is. I can ask them on Tuesday if you would like.
#9 | |
![]() Thank you! |
No problem! Already put the request in, should hear back Monday if they are open, or Tuesday. Thanks again
I just confirmed that this is not DOM tubing. They don't seem to carry this. Sorry about that...
The ultra quiet resonators are designed to be more than a resonator, but less than a muffler. We have put them on some high power cars with 3" exhausts and have always noted that the exhaust retains it's deep sound, but takes a big edge off, leaving it more "toned" and mellow.
I've found that bottle style resonators don't do much except take the edge off. Hope this helps! |
