Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Drivetrain
Closed Thread
Old 10-26-2011, 12:30 PM   #1
maverickmotorsports
maverickmotorsports is an unknown quantity at this point
Z33>SR20 Adapters back in stock!
PRICE LOWERED! $420 shipped for the adapter plate! 3 in stock.
Z33 Transmission to SR20 Adapter!
Hey Zilvia! We had a really good response to the original thread and we just got more adapters in!
These are the new Version 2 adapters. The new plates have a slight modification which allows a little more clearance with bottom mount turbos.
So why a Z33 transmission? Keep reading!
The gearing is superior to an SR/KA/Z32 transmission. All of the gears are shorter now so you won't find yourself stuck between 2-3 gear on courses any more. You can now leave it in 3rd gear and rip! Not to mention having a 6 speed transmission that is tough and not made of glass like any SR/KA transmission!
This transmission is also significantly stronger. There are local 9 second Z33's that have yet to blow a trans. STOP BREAKING STOCK TRANSMISSIONS! Check out the gear size comparison!
You will retain your SR Clutch/Flywheel. You do not need a Z33 clutch.
What you need for the swap:
-Adapter plate
-Transmission mount
-Driveshaft
-Shortened shifter bracket
-Modifying Z33 Bellhousing
-Stainless steel clutch line. There are many vendors out there who sell these.
Pricing:
Just the plate and hardware is $420 shipped
Additionally other mods are available in stages depending on what you want to pay for.
Bellhousing Machining. Not just any machine shop can do this because of the size of the bellhousing. $80 +ship
Shifter modification. You send in your shifter and it gets modified then sent back to you. $125 +ship
Transmission crossmember. You can retain the original rubber mount(aftermarket mounts will also work). $100 +ship
A video of the first drive.
The two-tone s13 in front has the Z33 trans installed.
ImportTuner feature on the car we did the prototyping on.
Once this is done, you become rad!
Thanks, George
-George Marstanovic
Sr to VQ transmission adapter, dual caliper brackets, high angle tensions rods, and more!
http://www.maverick-motorsports.com/collections/all
maverickmotorsports is offline
Old 10-26-2011, 02:55 PM   #2
abunai the drifter
abunai the drifter's Avatar
abunai the drifter is making his/her stupidity well-knownabunai the drifter is making his/her stupidity well-knownabunai the drifter is making his/her stupidity well-knownabunai the drifter is making his/her stupidity well-known
Send a message via Yahoo to abunai the drifter
does the shiftier fit in the stock position with this set up ???
screw you guys im going drifting
abunai the drifter is offline
Old 10-26-2011, 04:58 PM   #3
dwnshft2drft
dwnshft2drft's Avatar
Trader Rating: (28)
dwnshft2drft will become famous soon enoughdwnshft2drft will become famous soon enoughdwnshft2drft will become famous soon enough
Feedback Score: 28 reviews
i have S15 SR would i still retain the S15 flywheel and clutch? Or i have to change it into S13/S14 flywheel and clutch?
And $750 z33 used tranny is consider a good price?
LMK thanks!
dwnshft2drft is offline
Old 10-26-2011, 06:17 PM   #4
maverickmotorsports
It depends on the motor mounts. The pictures above show it slightly back(about 1-2"). But that car is using mounts which move the engine back from the OEM location.
LMK thanks!
The OEM flywheel is dual mass(ie. heavy) so it will not fit. It offsets the whole assembly. You'll need an S13/S14 style clutch/flywheel.
-George Marstanovic
Old 10-26-2011, 06:52 PM   #5
Black240Ct
have this on my car.. love it
Black240Ct is offline
Old 10-27-2011, 06:43 AM   #6
street240sx
street240sx's Avatar
street240sx will become famous soon enoughstreet240sx will become famous soon enoughstreet240sx will become famous soon enoughstreet240sx will become famous soon enoughstreet240sx will become famous soon enough
LMK thanks!
$750 is alot i paid 3 something for mine and i got an 06
street240sx is offline
Old 10-27-2011, 02:56 PM   #7
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
Did you ever find a method of getting a speedo signal?
brndck is offline
Old 10-28-2011, 07:30 AM   #8
NissanEnthus
NissanEnthus's Avatar
NissanEnthus is an unknown quantity at this point
You make some awsome products! Pm sent
NissanEnthus is offline
Old 10-29-2011, 07:57 PM   #9
abunai the drifter
s13
how much hp are you making and dose your trans fit in stock location
Old 10-30-2011, 12:14 AM   #10
reallygood101
reallygood101 will become famous soon enoughreallygood101 will become famous soon enoughreallygood101 will become famous soon enoughreallygood101 will become famous soon enough
I WANT SO BAD!!! wish my car wasnt running like s**t otherwise this would b my next purchase
reallygood101 is offline
Old 11-01-2011, 01:44 PM   #11
maverickmotorsports
You'd have to use the dakota digital speedo box along with an ABS diff. Or do something similar to an S15 setup(speedo in diff).
The trans fits in the stock location. If you have motor mounts that move the engine back you might have to slightly hammer in the trans tunnel (1/8").
-George Marstanovic
Old 12-24-2011, 02:11 PM   #12
street240sx
[QUOTE=george;4333144]You'd have to use the dakota digital speedo box along with an ABS diff. Or do something similar to an S15 setup(speedo in diff) [QUOTE]
Yea that's the right idea. I'm going to try that on my coupe when you make a Ka one
Old 01-05-2012, 04:13 PM   #13
maverickmotorsports
Admins/Mods please delete or close this thread.
New thread here: #/f/drivetrain/42818...ml#post4443447
-George Marstanovic
Closed Thread
