![]() Join Date: Mar 2011
Trader Rating: (50)
![]() Feedback Score: 50 reviews
SR20 Stuff and More
Shippin available at buyers expense + paypal fees. Unless stated.
Price reduced....... [B]I will only TRADE for: Z32 diff cover, Vertex or Cwest Wing, S14 fender brace, S14 Cf trunk, Defi Din Gauges kouki cf cooling panel ------------------ PICS SOON..... Sr20 Act HD street Clutch 5 miles -345 Shipped Sr20 Ignitor chip (good one)-45 shipped Sr20 Test pipe (5 miles)-35 shipped s14 Zenki Sr20 Ac comp + Cody Ace Ac kit (powder coated)200 shipped SR20 Starter (clean! Low miles)-125 shipped Z32 Rear Aluminum Spindles- [B]55/B] --------------- S14 signal/Headlight switch (swapped for se)-50 shipped SR20 coil packs 4(low miles)-130 shipped BMC HeatSheild (I manage to use this for s14 but I think made for S13)- 30 shipped S14 (came of clip 40,000 miles)oem jdm fr Swaybar with endlinks + New Energy sway bushings & Bracket- 60 Mazwork Sr20 Head Bolts- 120 Shipped Condition: Been torqued down Once only. Super Clean SHape. Nothing striped, Took close ups so u can see Better. Nismo Engine & Transmission Mount-235 shippedPrice Drop Condition: Mounted only. Sr20 Tomei Turbo Inlet Pipe & Fatty 02 Sensor-SOLD! Both Basically new, Idle time use only Sr20 Tomei Oil Block Adapter-90 shipped Condition: Idle time use only, Basically New Box is included if wanted please Request. Sr20 Shifter with OEM Rubber- Best offer Sr20 Down pipe with Flex joint- 100 Picked up / 120 shipped Brand: Megan Racing Years: 89-98 240sx Condition: Basically New, Bung Welded & Wideband Ready! JDM s14 climate Bezel w Card Holder- 110 shipped S14 Dust Sheilds- 7 each[/QUOTE] [B]S14 Sr20 Oem oil sender block (No sensor)- 40 Shipped S14 lower brace Oem brackets- SOLD! S14 4 LUG HUBS (REARS ONLY)=30 S14 BALLER BOLTS Fr Strut bolts- 25 shipped Slave Cylinder Low miles- 25 shipped FR. S14 brake calipers and lines (NO ROTORS)-40 Oem S14 Radiator panels (Don't know exact name)-20 S14 tension rods-15 S14 RHD ABS unit & abs lines- 90 S14 rhd jdm A/C High side line-10 RHD S14 air ducts (Under dash)-7 each S14 Battery/Ground wire- 7 each Last edited by Relentless240; 07-22-2015 at 10:48 PM.. |
