Old 03-05-2012, 06:25 PM   #1
BrokenLynkz
BrokenLynkz's Avatar
BrokenLynkz is an unknown quantity at this point
What would you run precision 6262, 6265,6266
If you had a built ka24det cammed out full standalone which one of these precision turbos would you run. Im bored just throwing some tech talk out there.
and besides the built ka 264 cams . you will have 750cc injectors and its a daily? Lets make a debate here gentlemen.
BrokenLynkz is offline   Reply With Quote
Old 03-05-2012, 07:09 PM   #2
R33E8
R33E8 is an unknown quantity at this point
Well what's your power goal? I'm going to assume it's not much more than 400whp on pump gas since you are only running 750cc injectors... In which case you would be better off getting a smaller turbo...
R33E8 is offline   Reply With Quote
Old 03-06-2012, 03:26 PM   #3
BrokenLynkz
i have my built allready 1000cc injectors and 6266 i was asking this as a genneral question i was bored
Old 03-06-2012, 03:27 PM   #4
BrokenLynkz
and i made 400 whp with my 550cc injectors and a 50trim turbo
Old 03-08-2012, 05:06 AM   #5
R33E8
well, the 6262 is good for probably 500 on pump gas.. The 6266 is all around better than the 6265... Makes more power than the 6262 but is a lot laggier.. If it matters, I went with a 6766 for my ka-t...
Old 03-09-2012, 08:12 PM   #6
BrokenLynkz
so what ar are you running on the turbine housing. I mean that thats the only thing i can really decide on with the turbo because if i get a 6266 with a .63 a/r wont it spool faster?
