Old 03-30-2015, 09:04 AM   #331
TheRealSy90
TheRealSy90's Avatar
You could just swap out the 20g for a 25g and keep all the manifold/downpipe parts and save a lot of money and fabrication time.
Such a good signature.
Old 04-06-2015, 10:18 PM   #332
jaxshawn
jaxshawn is an unknown quantity at this point
What size oil feed and drain for hx35 sorry if I overlooked it
jaxshawn is offline   Reply With Quote
Old 04-06-2015, 11:50 PM   #333
holslut s13
holslut s13's Avatar
holslut s13 is an unknown quantity at this point
"Oil return pipes are permitted to decline at an overall angle of not less than 30 degrees below horizontal.All turbocharger applications require a pipe of internal diameter greater than 19 mm which has integrated connectors. To ensure oil drains into the engine under all operating conditions, the return connection
into the engine sump must not be submerged and the outlet flange of the turbocharger must be 50 mm above the maximum oil level of the engine sump pan."
http://www.myholsetturbo.com/manuals...5_38_40_GW.pdf
holslut s13 is offline   Reply With Quote
Old 04-07-2015, 11:16 PM   #334
mkomar24
mkomar24 has made poor choicesmkomar24 has made poor choicesmkomar24 has made poor choicesmkomar24 has made poor choicesmkomar24 has made poor choicesmkomar24 has made poor choices
This is my setup in my S13, Holset HE351CW on an ebay manifold, USDM 2JZ 550cc injectors, walbro 255 external pump, -6AN feed and return, Greddy Emanage Ultimate. I use a Tial 44mm wastegate to make 20psi with full boost by 3500 rpm. Timing retarded 10 degrees on top, advanced 3 degrees down low to help spool. This thing pulls like a freight train and has no issue with lag. Very happy with the 9cm hotside. The radiator is in the back and feeds from a 4 foot wide scoop under the rear and two naca ducts behind each door. It runs 160 degree water temps even on the hottest track days. This is my perfect setup for me. Holset all the way!
mkomar24 is offline   Reply With Quote
Old 04-08-2015, 10:38 PM   #335
jaxshawn
Just got my holset today but can't find any info from the numbers on the plate
Assy. 4035961
Serial. H050201466
Customer 2853198
Model hx35
It's a non wastegate t3 twin scroll flange, v-band downpipe
7blade cold side
12 blade hot side
19L4 cast into hotside
Old 05-05-2015, 11:03 AM   #336
AngeloAJC
AngeloAJC is an unknown quantity at this point
im in the market for a HX40 T4 Divided exhaust housing if anyone comes along and has one
AngeloAJC is offline   Reply With Quote
Old 05-10-2015, 11:14 AM   #337
KAT-PWR
KAT-PWR's Avatar
from turbo lab america
This pic more shows how much bigger holset hotsides look than what they actually are
MRP Manufacturing
Old 01-05-2016, 06:19 PM   #338
dave123thomas
dave123thomas is an unknown quantity at this point
Does the oil feed line from a t25/28 fit on the holset or will I need to get an adaptor
dave123thomas is offline   Reply With Quote
