Old 04-04-2014, 04:16 PM   #1
xninjaxkirbyx
xninjaxkirbyx is an unknown quantity at this point
mechanic needed
do you guys know any good mechanic for 97 240sx around rancho cucamonga to rowland heights? i have some oil leaks want repaired. preferably if they can work on weekends cause i work weekdays.
xninjaxkirbyx is offline   Reply With Quote
Old 04-04-2014, 04:35 PM   #2
dallasb53
dallasb53 is an unknown quantity at this point
most seals can be repaired fairly quickly, even the rear main if you have access to a lift lol
which seals are leaking? its probably your front main, they are notorious in ka's
dallasb53 is offline   Reply With Quote
Old 04-04-2014, 04:41 PM   #3
xninjaxkirbyx
i believe it is power steeling and oil pan gasket. i also need new engine mounts cause my car shakes when i start it up.
