Damaged S15 HLSD Half Shaft
Hey guys, decided that the 240 needs an LSD and chose a HLSD from an S15 as the upgrade. Picked one up from an ebay vendor from Japan and the HLSD with half shafts got here real quick. Unfortunately it wasn't packaged well and one of the half shafts has damage. I've never worked on one of these, but looking at it I get the impression that this isn't going to work with the oil seal.
What do you guys think? https://imgur.com/CJiMin2 |
#4 | |
Also I've been reviewing this install for a while and I think I got it mostly figured out, but I'd appreciate a second set of eyes. Tool wise I know i have shim drivers, feeler gauges, a dial test indicator, digital torque wrench, and a spring gauge. I've got some gear marking compound too. All that stuff should let me validate everything is dialed in. The suggested gear oil seems to be either 80W90 or 85W140 and I was thinking of using Valvoline High Performance non-synthetic stuff. I recall torsen style LSDs not liking synthetic or lsd additives, am I wrong there? I also ordered some new oil seals, just in case they're dry rotted and I hit up enjuku for some aftermarket bushings. |
![]() Join Date: Jan 2010
torsen style LSDs do not need any sort of additive in the oil. i dont recall hearing it would hurt the torsen if you had fluid that had additives though.
no idea. dont own these cars.
if you dont get your answer here, search i can guarantee you its been covered before. edit: this looks like it may have your answer: http://www.nissansilvia.com/forums/t...il-is-correct/ |
#8 | |
![]() Join Date: Oct 2004
You need special S15 bolts to bolt the HLSD to a standard ring gear.
Did he send you those bolts? Different from S13 and S14's. That have a visible hump on them. https://frsport.com/nismo-38102-rs50...saAq5ZEALw_wcB Also would change your input and output shaft bearings while you at it.
Turn and Burn!
#10 | |
Bolts same torque rating wise? I'm just following Nissan's FSM. |
#13 | |
Ilya, I do have a big table vice attached to my work bench. I figure impact to remove from from old diff and the new ones I'll use a power ratchet to get em close and then just hand torque with a torque wrench. |
