Garage Clean Out! RB, S14, KA, etc
I have the following items for sale. I will accept reasonable offers on most everything but please do not low-ball me. Contact info is located below.
KA Stuff OEM S14 Radiator with shroud and hoses. Good shape with no leaks. A few bent fins as expected for a used radiator. $45 ![]() S14 Intake with all hoses, tubes, and MAFS. Normal wear $40 ![]() KA24DE Starters. Both are in good working order. $25 ![]() KA24DE ECU’s – Both are auto. One is from a S14 and the Re-manufactured is from a S13. $25 ![]() ![]() S14 Auto trans ecu – Good shape. Removed after 5spd swap $15 ![]() KA24DE power steering pumps – Good shape. $20 ![]() S14 Resistor..forget what it is for $4 ![]() S14 Chassis Stuff S14 base model wiper and combination switch $10 each ![]() S14 door latch. $20 ![]() S14 windshield washer reservoir. Good shape. No leaks. $12 ![]() S14 passenger airbag. $75 ![]() S14 rear sway bar. Includes mounting brackets $45 ![]() S14 passenger side corner light. No cracks or major damage. Light scratches. Can be sanded out. $15 ![]() S14 metal shifter ring that is used to mount the rubber boot. $5 ![]() RB Stuff RB20DET Coil packs. Good shape. All boots are included. $15 Each ![]() RB20DET OEM crossover pipe with bypass valve. $30 ![]() RB25DET intake manifold. Upper and lower parts only. No accessories. $40 ![]() RB exhaust manifold. Modified with external gate with built in extension. $35 ![]() RB20DET oem injectors. Set of five. $8 each ![]() RB20DET valve cover gaskets. Used but in good shape if your in a pinch $25 ![]() RB20DET crank sprocket. Used. Shows signs of wear and hammer marks. Some teeth are slightly damaged. Shouldn’t effect usability. $18 ![]() RB20DET air regulator. Good shape. Painted blue. $16 ![]() Misc. DEI intercooler sprayer. Good shape. $35 ![]() Autometer 2 5/8” carbon fiber volt gauge. New in box $20 ![]() Holset hx35/h1c downpipe flange. $20 ![]() SR downpipe. Was used in my RB swap. Might be able to get you close if doing an RB. $35 ![]() All Prices are plus shipping. I accept paypal payments only. If you have any questions please do not hesitate to ask. Texts messages will yield the quickest response. 865-323-5760 Last edited by xxsptcuztomsxx; 04-30-2012 at 09:05 PM.. |
#13 | ||
15 shipped. Quote:
55 shipped. Let me know. Yes they all work. I don't sell broke shit. I switched to GN coils on my RB Metal ring is sold. Sorry Possibly. What do you have? What are you interested in? No, sorry bud. |
#19 |
#21 |
