![]() Join Date: Oct 2008
Z32 master plug fix.
So I figured out a easy fix for the Z32 master upgrade.
I got a 1 and 1/16 z32 master by nabco. All you have to do is get the inverted flare euro brake line fromyor local parts store. I got mine at oreilly's auto parts. Screw it in .Bend it into position for the left side caliper .Double flair it and done.Easy. Cheap easy fix. |
![]() Join Date: Dec 2009
I agree. I've simply taken a double flairing kit and done just the first flair to reproduce a bubble flair many times for line repairs. It comes out a bit longer in the actual flair but when it gets tightened down it "forms" to the inside of the female end of the fitting.
