Guest
Posts: n/a
ok look i know what a clutch is and what it does (connect the trans to the engine) but how does it do this and what is the best (if there are diff versioins) clutch you can get and what are the pros and cons thanks a lot <img src="#/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
AutoX Junkie
this should give you a basic overview on how clutches work
<a href="http://www.howstuffworks.com/clutch.htm" target='_blank'>http://www.howstuffworks.com/clutch.htm</a> |
