#61 |
![]() Join Date: Feb 2013
![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
Any chance any one knows if z33 fitting r the same? Looking to do z33 rack swap next time I need a rack cuz finding a good S chassis hard to come by.
#62 | |
![]() Join Date: Oct 2006
Here is a link to a forum where it indicates thread sizes for the ps rack. https://my350z.com/forum/engine-driv...placement.html If you skip to 8 minutes in you'll watch the guy unbolt the low pressure fitting. https://youtu.be/sY6heJ3-rbY Here is a screenshot of the YouTube video. ![]() I've had some overseas people buy fittings for their r32 and advised that they work on other Nissan's. I just can't physically guarantee that they fit. Hope this information helps out! Last edited by k00laid83; 12-13-2019 at 10:17 PM.. Reason: Fixing all of the photobucket issues |
#66 |
Hope everyone is doing well. Just wanted to give everyone an update. The fittings are currently being machined. The machine shop advised that I would get the fittings hopefully early next week. As a reminder I will be testing every fitting on my spare rack before shipping.
#70 |
![]() Join Date: Jul 2005
When i destroyed my rack high pressure threads, a friend helped me take the piece of aluminum off the rack (its like 2 bolts plus the steering shaft) and he welded a -6an into where the old threads used to be. The housing has 2 O-rings inside it where it goes up into the shaft.
Still leaks fluid but I found it was seeping out of the double O-rings under the steering shaft part. |
#71 | |
#72 |
![]() Join Date: Jun 2010
Probably one of these. My rack leaked from the top of the pinion too.
You can get an aftermarket rack seal kit, or just those few from the dealer, for about $50. edit: the "Pinion Oil Seal" at the bottom should be highlighted too. ![]() |
#73 |
UPDATE!!
Well I got the fittings in my hand. I'll be testing every single fitting on my spare rack once I get home. Let me tell you these fittings look great! If anyone is interested in a set of fittings please make sure to hit me up. They shine nice in the sun. ![]() A closer up pic of the fittings. ![]() Side by Side pics with the new fittings and my prototypes. ![]() Last edited by k00laid83; 12-13-2019 at 10:21 PM.. Reason: Fixing all of the photobucket issues |
#74 |
Hi everyone,
Just letting everyone know that I have plenty of sets available. If you're interested in a set please don't hesitate in contacting me. Thanks |
#75 | |
![]() Join Date: Oct 2004
Also to finish your powersteering system, here is the fitting for your pump which gets rid of the banjo bolt. Its flow controlled as well. https://www.krcpower.com/ecommerce/p...c-25304000.asp
Turn and Burn!
#76 | |
#77 |
Its just a banjo bolt with 2 washers. Just straight thread it out.....
I assume SR20 PS Pump vs. KA PS Pump is the same
Turn and Burn!
#78 | |
Guess I need to dig around the garage and see if I can find a KA PS pump to use, I'd love to get rid of that damn factory piece.ETA: I think the ones with the threaded stud are S14/S15 SR power steering pumps.
#79 | |
#80 |
All pre-orders and standard orders have been shipped or ready to be dropped off tomorrow to be shipped. If you're interested in a set please do not hesitate in contacting me.
#81 | |
Turn and Burn!
#82 | |
#83 |
Yeah, I need to pick up the fittings from kool, already have p/s line and fittings to make, just need to try and find a banjo bolted ps pump so I can replace that fitting too. Pretty sure I have one laying around.
#84 | |
![]() Join Date: Mar 2009
