![]() Join Date: Oct 2008
Trader Rating: (48)
![]() Feedback Score: 48 reviews
r33 gts-t calipers with the right rotors
We all know r33 gts-t Calipers are like the black sheep of the 4 pot sumitomo calipers family. Their 296mm x 30mm specs make it hard to get the right rotors to fit unless you got the actual rotors from that chassis. Well look no further and no more settling with the 96+ q45 rotors which you lose 2mm nominal thickness due to the q45 rotor specs 296mm x 28mm. Now you can have the perfect fit rotor, please refer to the links below...
AutoZone 1992 Dodge Stealth AWD Turbo or Mitsubishi 3000gt VR-4 AWD Turbo Rotors Duralast/Brake Rotor - Front (31004) | 1992 Dodge Stealth 6 Cylinders C 3.0L MFI Turbo DOHC | AutoZone.com_ O'reilly BrakeBest Select 96159RGS - Brake Rotor | O'Reilly Auto Parts Clarks Discount Auto Activant Cover-to-Cover So there you have it 3 Places you can get the rotors from. |
#6 | |
have u gone to AutoZone and have them checked out to see it these rotor in deed work? i am planing on picking up the caliper but i just need to get more info on the rotors so i can make sure i can make this work! thanks in advance! |
they ship from australia tho and are around the 190~ price range each side* definitely not cheaper than local autoparts store but im sure the race quality's much better than any duralast stuff youll find* i got lucky my r33 gtst calipers came with rotors. just turned them and there about .08mm before min acceptable thickness, so planning on dba's soon in the future* DBA 4000 Series T3 Slotted Brake Rotor Suit Front Nissan Skyline R33 GTST | eBay |
#11 | |
![]() Join Date: Oct 2011
![]() Feedback Score: 15 reviews
Sent from my HTC6500LVW using Tapatalk
MmmmmmTACOS |
