sr20det experts!!! need help with power steering!
my car is 91 240sx fast back with ka that has the nasty hicas
i swaped to sr20det redtop ........ with hicas!!! During the swap process we installed the ka hicas power steering pump since the piping were direct bolton , i was told , and blocked the rear hole since i cancelled the hicas system now my steering feels ok but not the way i wanted it to be ( ex 350z owner ) my question is how to improve the power steering? - should i get a 240sx non hicas power steering pump, from which model? to bolt on directly to my hicas redtop? - should i get a smaller pulley , will that help? attached is a my hicas redtop power sterring pump any help would be great , thanks |
![]() Join Date: Jun 2011
hicas delete kit for the rear. regular sr power steering pump bracket, non hicas sr/ka pump. solid steering linkage bushing. boom
BustedS13: anything you can hide on your person is free. junkyard law. Last edited by e5s4y; 02-22-2013 at 11:41 AM.. Reason: forgot a word |
![]() Join Date: Mar 2009
You cant just block the rear pump, you have to dissasemble the rear portion and take out the metal plates that pump the fluid.
I'm running a hicas pump on my non hicas car and it works perfectly. |
