Old 01-08-2009, 11:57 AM   #1
handinpants
FreshColdBeer.com
handinpants's Avatar
Trader Rating: (48)
handinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud of
Feedback Score: 48 reviews
Send a message via AIM to handinpants
s13 need help asap- testing compression s13 sr20det cranking ?s
I am testing the compression on my s13 sr20det, I want to know what the amount of full cranks i need to do to get an accurate reading. I am doing 5 cranks right now and got these readings. 145 -140-145-145 being the first reading is the pistion closest to the radiator.
please help because i need to know how many complete cranks i need to do to get the proper reading.
handinpants is offline   Reply With Quote
Old 01-08-2009, 12:22 PM   #2
obsolete
obsolete is an unknown quantity at this point
5 cranks should be enough. should stop as soon as pressure stops going up.
obsolete is offline   Reply With Quote
Old 01-08-2009, 07:59 PM   #3
Monooxide
Monooxide's Avatar
Monooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to behold
Your compression is good, the main thing is to make sure the values are reasonably close to one another. Your readings could be low because of a crap gauge.
Previous poster is right, crank until the pressure stops going up.
Monooxide is offline   Reply With Quote
Old 01-09-2009, 11:24 AM   #4
handinpants
FreshColdBeer.com
Trader Rating: (48)
someone else told me this, i used a snapon guage though. my shop teacher says 5 cranks, but he's been building v8 hot rods for a while
Old 01-09-2009, 11:30 AM   #5
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
5 cranks is enough...plus the number you got are pretty consistent for an SR20. If it lower than 125-130, then i'd start worrying.
CLICK HERE!!!
