Sr20 s13 red top clutch
Alright so I tried to post this in drive trains won't let me. But here's what I got. Sr20det red top swapped s13. Runs and drives great but I hate the clutch that is in it. It's "fully" built lol still on stock injectors and t25 still running 7psi. Should be getting 1000cc injectors and not sure what turbo to run but low on funds so for now I'm looking for a better clutch. Welded diff, building a street drift car but also a daily. What are a few clutches you all are running that you like. At the end of the build should be making close to 500 to the tires. Thanks
![]() Join Date: Nov 2010
What do you hate about the clutch ? Wth that much power you're going to need a heavy pressure plate and that's going to probably mean stiffer clutch pedal.
What's in there now? And what are you wanting in a Clutch
Honestly not sure what's in the car, came with it. The clutch that is in it is very inconsistent some times it catches hard as fuck others it's a nice easy start. I'm looking for consistency. Stiff doesn't bother me I'm just looking for a nice feel and a low ish catch point.
| clutch, red top, s13, sr20 |
