![]() Join Date: Oct 2006
im about to work on my front bumper and i was wondering if any one and some tips/tricks i could know about befor i screw up my bumper? im gonna be useing spot bondo/putty. thanks
Man w/ CTSV & a Car Seat
yups...dont use bondo. Its fiber glass, so use fiber glass. Depending on what your doing to it, will depend on what fiber glass to use. If your just smoothing it out, sand down all the paint, then buy one of those resin/fiber hair mixed setup. For big cracks and fractures, do it right and buy the clear resin goo and fiberglass sheets seperate. Again sand the paint off, trim the crack so itll sit flushed against each side, cut a piece of fiberglass sheet to cover it, use a paint brush and lay the resin on the fiberglass.
#6 | |
![]() Join Date: Jun 2004
yes.....kitty hair.
and, skim coat of some gooooood shit to get it strait as glass, like Rage extreme or something. not Bondo brand wal-mart shit. use the LONGEST sanding block possible, that will help insure straightness.
i dont have any pics, i can get some pics tomarro when im working on it more. my dad told me to use spot putty and hes been doin body and paint for 25 years for i took his advice
416 EVERCOAT putty. KittyHair is total overkill if all your doing is filling scratches. KittyHair is used to reinforce and mend cracks or small holes in fiberglass. Use multiple thin coats, rather then one thick coat toprevent air bubbles.
What the hell is "BALLER" or "GANGSTER" status, about a 240sx? |
![]() Join Date: Jun 2003
spoty putty is ehhhhh. it never really hardens since its only a 1 part filler. if its just scratches like 300 grit sandpaper you can just spray epoxy primer over it, hell the clear coat will even fill in 300 grit scratches. how bad of scratches are they. or what.
![]() Join Date: Nov 2006
hey all you need is to take a DA sander with some 320 grit sand paper and sand down the scratches and the entire bumper..NO MATTER WHAT you are going to have to do this any ways so the primer will stick to the bumper. I've been doing body work and painting for a few years now if you need more help on what exactly todo pm me ill help you out. good luck
No more nissan.
![]() Join Date: Jan 2003
Tips: don't use bondo on a fiberglass bumper (as afore mentioned)
If you insist on using bondo use as little as possible. Question: If your dad has been doing paint/bodywork for 25years.. why are you asking US for tips and not him?
#15 | |
spot putty is exactly what you should be using; your dad is correct.
Body filler (bondo brand) is for worked metal surface. Although bondo brand body filler blows balls. Use Evercoat Z-Grip body filler, best on the market.
![]() driftingisgay.com |
#17 |
sorry im biteing on your thread but no sence starting a new one and waisting space for the mods. would you use spoty putty on a dorr that has a weird shaped dent that ccanot be poped out? the dent is has a seriece of dents all in one and its really bad looking, just needed a tip on how you fix it
1990 Acura Integra- Deer (mother fucker) 1993 240sx- still tickin |
![]() Join Date: Jan 2006
... how big is it
if its like a tiny ass dent then yeah just get it down to bare metal and use the metal glaze. If its bigger than like 2 inches or w/e use filler. Evercoats the good shit.
ho ha ho chi chi |
#19 |
remember MORE is better when it comes to bondo! slather it EVERYWHERE! have a dent? DONT WORRY, bondo it!
also, after bondoing, primer the car and leave it like that for a long time and just tell everyone you are getting a real paintjob soon, different colors of primer will get you the ladies.
#21 | |
anyone with over 3 green feedbacks is OBVIOUSLY a tool ![]()
#23 | |
No more nissan.
#24 | |
![]() Join Date: Nov 2005
www.dictionary.com |
#26 | |
please tell me you meant to do that I can see the cover now. TERMINUS2K's LEARNING TO SPELL LIKE A NOT RETART You culd lern reel good to spel. gwaranteed
ho ha ho chi chi |
#29 |
any ways back to the bumper im working on. i used the spot putty on some chips and deep scratches and im gonna get some thick primer to fill in the smaller scratches.
#30 | |
Body filler is only use to cover up metal work.
