| Advertiser Specials and Sales Dedicated for Zilvia Advertiser Sales and Specials |
![]() Join Date: Jun 2002
P2M Upgraded Nissan S13 S14 SR20DET Ignition Coil Packs Now Released!
P2M Nissan S13 S14 SR20DET (RWD) ignition coil pack set is a direct replacement over the factory unit with the following improved features:
- Strictly produced via TS16949 certified manufacturing facility - Top quality high insulation expoxy - Top quality high voltage di-electric resistant resin - 15% stronger spark output than factory unit - Increased winding and improved iron core - Dyno proven performance (+4rwhp / +5 ft lbs torque peak to peak) - Compatible with all aftermarket ignition box upgrade ** Dyno graph based on stock S13 SR20DET running stock 8-9psi (0.6bar) ![]() ![]() Can be ordered directly through our website or any P2M product distributors: http://www.phase2motortrend.com/prod...cp50f01-tt.htm
![]() 909-594-3619 Business Hours: Mon-Fri 10am-6pm (Pacific) email: [email protected] http://www.phase2motortrend.com |
