FS/FT Tons of S13/SR Parts! OBO! Ship!
Hey guys... sadly my sr20 is shot, hole in piston 4. All pieces were installed and have no miles put on them by me. Car idled fantastic but constant smoke. Figured head gasket or something but found the hole instead... Block was sold to me by some random person and now im sh*t outta luck. Moving on and parting out to recoup some loses. All items are used except otherwise noted, New items only saw idle and rev up to 2.5k max. As the title states all prices are OBO unless otherwise noted. Also, Will ship anything but you pay. Located near Albany NY
I'm looking for things like aftermarket KA radiator, Type X front aero or rear valence, Aftermarket seats, bucket or reclining. Steering Wheels as well (White or Wood, Nardi, NO DEEP. Dish is ok, Deep is too much 2) Ebay Intercooler $$80$$ Clean NEW Also Have all of the 3 inch piping, aluminum to go with this, discuss pricing on that if interested! + All couplers mostly black some blue i think 1 red, 90s, 45s, 3 to 2 90. Stock SR Fuel Rail with injectors $$100$$ Nismo SR Fuel Pressure Regulator Type B I think $$80$$ NEW SR Throttle Body W/ S14 Cable Holder thing $$45$$ SR IACV $$45$$ Idle Screw is kinda chewed but works none the less Together Price: $$375!$$ 4) Mishimoto Radiator Fans $$150$$ 5)Agency Power Manual Boost Controller $$80$$ NEW 6)SR20 Coilpacks W/ Harness (Not pictures but mint) $$90$$ 7)Dif Fan Controller NEW its like Version D now or something... Have most of the wiring still like inline fuse and such, will include. $$110$$ 8)SR Ignitor Well Not SR But works with SR... Looks cooler too $$40$$ 10) PBM Curved T25 Intake Pipe W/ Orange couplers $$70$$ NEW 12) SR Altenator W/ Lightweight aluminum pulley $$75$$ 14) XTD Clutch Stage 2 or 3 Not 100% on this. FITS KA Brand New untouched! $$170$$ 15) Circuit Sport 3" DP Barely Used $$90$$ DIDNT FIT WITH NISMO MOUNTS 16) Stock KA Clutch... Pressure Plates way rusty but the pad has tons of life! $$30$$ 17) Trust Exhaust 3" Never used, Bought on here some long time ago. Ended up getting a Kakimoto Racing Catback which i eagerly installed instead... $$300$$ 18) Nismo SR Flywheel $$200$$ 19) SR Clutch + Pressure Plate In good shape, has life left $$85$$ With Flywheel $$250!!$$ 20) SR Cam Angle Sensor $$65$$ 21) S13 Steering Wheel with CC $$35$$ 22) SR Wiring Harness. Redtop/S13 $$125$$ Everything's there and works. Wired for Z32 AND SOHC Maf. Injector wires extended to run between plenums with harness under. 23) Redtop Cover Painted Black $$75$$ Just needs cleaning, paint was fresh.24) Exhaust Manifold (J-TOPS, I believe... whatever that is) $$80$$ Circuit Sports or ISIS, not 100% NEW $$80$$ Circuit Sport Turbo Lines (Bottom Mount) $$100$$ ++**Not Pictured but included HKS Wastegate for T25/T28 $$75$$ + Downpipe listed above for: $$400!!$$ Items Sold: 11) Ebay BOV SOLD 3)ISIS Polished Intake Manifold SR20 SOLD 24) Exhaust Manifold (T-Pros, I believe... whatever that is) SOLD 1) Redtop ECU 62 SOLD Stock T25 Little Shaft Play, No contact whatsoever, spins well. SOLD 9)Z32 Maf SOLD 25) Z32 Fuel Filter SOLD Greddy Swivel Adapter NEW SOLD 13) SR Starter *It Starts!* SOLD Last edited by l2edken; 07-15-2011 at 08:20 PM.. Reason: items sold |
nismo mounts raise engine 3/4 - inch making the flex portions make contact with the under panel, roughly where your gas pedal is. The flex section comes out a good bit from the original 3" pipe.
#28 | |
460
