Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Group Buys
Group Buys Dedicated Forum for Group Buys.
Old 02-14-2007, 08:38 PM   #1
MajorMods
MajorMods is an unknown quantity at this point
1st KSPORT GB from MajorMods
Ksport Coilovers
5 MINIMUM BUYERS - I'd like to see 10 just to start off with!!!
Ksport Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride.
The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
Key Features:
* 36-way adjustable dampening
* Made from high quality 6061 Aluminum with T6 for increased hardness
* Compression/Rebound adjustable
* Adjustable spring perch for height adjustment
* Adjustable body allowing maximum suspension travel
* Pillow Ball Top Mount w/ adjustable camber (not available for some models)
* Monotube High Pressure Design reduces oil leakage
* Electroplated body for protection from corrosion and rust
* One Year Limited Warranty
FYI to all, ksport makes many different models of the coilover. The kontrol pro is the cheapest model they make but well worth it. They also have these available:
s13 gtpro - $1660 retail
s14 gtpro - $1710 retail
s13 slide kontrol - $1450 retail
s14 slide kontrol - $1500 retail
s13 kontrol pro - $1200 retail
s14 kontrol pro - $1250 retail
I CANNOT list the pricing in the GB section as its STILL below KSPORT wholesale prices.
PM me for pricing or email me at [email protected]
I have many happy neon, sentra, g20 and other car owners to back me up on my feedback rating!!! Post the positive feedback in here so everyone will have a authorized ksport vendor they can trust! To view feedback please check these forums under the following usernames:
sr20forum.com - black2kse
b15sentra.net - 2kblackse
g20.net - 2kblackse
neons.org - nicksamba (my employee who controls alot of forum sales)
price might be lower!! pm to find out
MajorMods is offline   Reply With Quote
Old 02-15-2007, 03:15 AM   #2
sr20drft
sr20drft is an unknown quantity at this point
I've always wondered if the gt pro's are any good............
They are inverted monotube in the front like many of the better coilovers that are a decent price(kts/stance).
Anyone have any feedback on them or is there any other information than what's on there site?
I'd like to know piston sized on the gt pro's.
Also, any information on the Ksport Circuit Pro's?
sr20drft is offline   Reply With Quote
Old 02-15-2007, 05:48 AM   #3
MajorMods
replied to via PM for pricing. I am going to look into finding out about the circuit pro's today and any further details I can get for ya.
Old 02-15-2007, 08:43 AM   #4
zoototheyork
zoototheyork has made poor choiceszoototheyork has made poor choiceszoototheyork has made poor choiceszoototheyork has made poor choiceszoototheyork has made poor choiceszoototheyork has made poor choiceszoototheyork has made poor choices
price shiped to 07801?
zoototheyork is offline   Reply With Quote
Old 02-15-2007, 09:28 AM   #5
MajorMods
u got a PM sent to ya.
Old 02-15-2007, 05:18 PM   #6
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
price shipped to 91902?
Also, i have a set of ksports on one s14 of mine. They seem ok, but would you be able to tell which model it is?
gotta240 is offline   Reply With Quote
Old 02-15-2007, 06:16 PM   #7
MajorMods
i dont believe I could tell the model difference. I can ask ksport how to distinguish the difference but they pretty much all look alike.
FYI to all, the circuit pros are NOT in production yet. Also, any ksport product is available such as the ebrake, lowering springs, etc.
Old 02-15-2007, 10:17 PM   #8
sr20drft
Kontrol Pro's - Mono tube, non inverted
Slide Kontrol Pro's - Mono tube, non inverted, helper springs in the rear
GT Pro's - Inverted mono tube front, non-inverted monotube rears
Old 02-15-2007, 10:46 PM   #9
gotta240
what does inverted vs non inverted look like as far as visual differences?
Free bump for MajorMods for being SUPER helpfull. May be looking into the gt pros soon!!!
Old 02-15-2007, 10:52 PM   #10
MajorMods
even this I am interested in. I dont think Ive actually seen an inverted vs. non-inverted up close so I didnt think there was a visual difference. I guess I could be wrong... and its a pleasure to help ppl when they got questions... isnt that what customer service is all about!?
please visit our website in progress:
www.majormods.com or you can email us at
[email protected] and all payments can be via cashiers check, MO, or paypal. the paypal addy is:
[email protected] and always remember to add 3% to all payments. THANKS!
Old 02-16-2007, 04:14 PM   #11
sr20drft
just look at the dampers.............
between the springs where the dust covers are...........
if it's non inverted, you will see the pistons, if you see a thick metal casing, it's most likely inverted.
Old 02-18-2007, 11:39 PM   #12
MajorMods
thanx for the help... the guy asking was privately emailed and its all taken care of... guys these are for sale and CHEAPER than the megan racing ones I am also selling
Old 02-28-2007, 05:26 AM   #13
MajorMods
so far only ONE kit has sold.... any more needed?
Old 03-01-2007, 07:13 PM   #14
DrifterProdigy85
DrifterProdigy85 is an unknown quantity at this point
Send a message via AIM to DrifterProdigy85
Price for S13 each to PA, 17327. I still need to decide which to go with.
1995 Nissan 240sx
*RB25DET*
DrifterProdigy85 is offline   Reply With Quote
Old 03-01-2007, 08:03 PM   #15
dreaMervaj
Trader Rating: (18)
dreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-known
Feedback Score: 18 reviews
Price for 97-98 S14 to 29323.
Thanks.
dreaMervaj is offline   Reply With Quote
Old 03-02-2007, 02:51 AM   #16
MajorMods
u both got a PM
Old 03-04-2007, 12:32 AM   #17
brewster240
brewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond repute
Send a message via AIM to brewster240
s13 to 10509
brewster240 is offline   Reply With Quote
Old 03-04-2007, 01:34 AM   #18
BOROSUN
BOROSUN's Avatar
lemme know the price for s13 gt-pro to 94080
Old 03-04-2007, 09:10 AM   #19
CA18_S13
CA18_S13's Avatar
CA18_S13 is a well-known jackass
S13 to 23464
CA18_S13 is offline   Reply With Quote
Old 03-04-2007, 10:55 AM   #20
PXRdriFT
PXRdriFT is just really nicePXRdriFT is just really nicePXRdriFT is just really nicePXRdriFT is just really nicePXRdriFT is just really nicePXRdriFT is just really nicePXRdriFT is just really nicePXRdriFT is just really nicePXRdriFT is just really nice
Send a message via AIM to PXRdriFT
S14 to 91739
PXRacing.com
PXRdriFT is offline   Reply With Quote
Old 03-04-2007, 11:32 AM   #21
MajorMods
everyone has a Pm
Old 03-04-2007, 06:15 PM   #22
Farzam
Farzam's Avatar
Farzam is close to perfectionFarzam is close to perfectionFarzam is close to perfectionFarzam is close to perfectionFarzam is close to perfectionFarzam is close to perfectionFarzam is close to perfectionFarzam is close to perfectionFarzam is close to perfectionFarzam is close to perfectionFarzam is close to perfection
Price shipped for all s13 coilovers to 27613 or a business in 27509? Thank you.
loading HATERS.....99% ███████████████]
Farzam is offline   Reply With Quote
Old 03-04-2007, 08:45 PM   #23
MajorMods
u got a PM as well
Old 03-05-2007, 11:27 AM   #24
highoctane
highoctane is on a distinguished road
price for s14 shipped to 39759?
highoctane is offline   Reply With Quote
Old 03-05-2007, 02:03 PM   #25
Okinawandrifter87
Okinawandrifter87's Avatar
Price for s13 shipped to 95826? thanks!
Old 03-05-2007, 02:23 PM   #26
MajorMods
u 2 ^^^ got a Pm
Old 03-12-2007, 03:02 AM   #27
timeless24
timeless24 is a well-known jackass
s13 shipped to 11429
timeless24 is offline   Reply With Quote
Old 03-12-2007, 05:49 AM   #28
MajorMods
u got a PM also
Old 03-12-2007, 10:11 PM   #29
speed_racerx
speed_racerx's Avatar
speed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to all
Send a message via AIM to speed_racerx
S13 shipped to 90813
speed_racerx is offline   Reply With Quote
Old 03-19-2007, 04:12 AM   #30
domo dorigato
domo dorigato is an unknown quantity at this point
Send a message via AIM to domo dorigato
shipped to 94591
domo dorigato is offline   Reply With Quote
