Well, I just bought my first car...
Searched a lot for this problem, but couldn't find anything. '91 S13 sr20det redtop swap. This is what the seller posted. " -RedTop Sr20det With about 55,000 miles (chassis has 240k) -TOMEI Exhaust Manifold (bought this for $600) -New GodSpeed T25 Turbo(pushing 10 psi of boost) -3" Downpipe -Apexi Head Gasket -ARP Headstuds -BC Valve Springs -Lime green pullies -Big Front mount Intercooler -Knockoff Greddy BOV -Upgraded Walbro Fuel Pump - 4.5' Bolt On Catback Exhaust(Loud AF! Not no RICER Sound: Nice Deep tone!Beast)---- He had to take it off because cops pulled him over. He was gonna bring it to me, but I don't really care now. -Audi MAF Sensor -Exedy Stage 1 Clutch - aluminum radiator - Dual electric Audi Fans -Stock brakes -Lime Greens rear subframe -Tokiko suspension on 2.5inch drop Zenn springs -LSD (no welded Diff) -Battery Located to back -ADR 17' rims Good Thread on tires -Rear Spoiler & Hatch Visor _Has all Interior 7/10 _Nismo Shift Knob _GOD SPEED 3 Guage Pillar(water temp, Boost,Tachnometer) _Power Windows, Sunroof _Cracked Dash( like most 240s) _Has few Dents here and there Not to bad _could use a Paintjob bit faded on hood _No A/C _Has P/s Leaking a little bit of fluid. " $3500... Overpaid? There are few problems. When I bought it, it was running and idling good because the engine was warmed up and my mechanic said everything is alright. Drives good, idles bad. I still need to change the oil on the car. Won't start without MAF. It seems to have AUDI/VW MAF. AUDI fans. Has a power steering leak. Might have a boost leak, have to test for it yet. The car is really hesitant to start when the engine is cold. I need to press the gas pedal to keep it running when starting until it idles by itself. After I see that it can hold idle, it idles at around 1.5k RPMs. I have to open the hood and adjust this: which I am not sure what this is, but my best guess it's IACV. When I adjust this valve after it has warmed up, it runs perfectly. Here is a video of it: http://youtu.be/WLB_D32LCHo Notice, after I revved it up, it started idling. It happens most of the time, so the engine might be getting flooded or something. Few pics of it: ![]() I am pretty sure that hole has to be plugged, but correct me if necessary. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Any help would be greatly appreciated. Thank you. Last edited by Aurimas; 11-01-2012 at 12:18 AM.. |
![]() Join Date: Sep 2005
![]() I cant tell if this is capped off or not, but yeah you overpaid. Remove that boost controller, get the correct mafs, pull codes, boost leak test, check timing and search the forum. Wow, another Half broken 240sx for 2012!
#6 | |
![]() Join Date: Jun 2007
![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
I could understand if you had money and don't mind spending couple of grand fixing it up. But your BROKE!!! You don't buy shit like this. Get rid of this shit and get yourself a none modified 240sx if that is what you want. And take it from there. Lately 240sx have been becoming way overpriced, even beat up trash that should be going to junkyard and smelted are being sold like they are gold. You might wanna try get into another RWD, for example Q45's are pretty cheap, g50's are selling around $1000 in great running condition. 300hp factory with none of that pop the hood bullshit idle this adjust that. Y33's are $2500, better looking in my opinion. Both have LSD factory and can easily drift without modifying a single thing. |
| iacv, idle, knock, maf, sr20det |
