![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
Im parting out my SR. Anything SR related I will sell. The engine has less than 10k on it since STP Motorsports (Davie, FL) rebuilt it for me. I am having a slight oil issue in the head other than that the engine is solid.
The head is being parted out BC STD Valves - $120 OBO PRICE DROP!!! OEM Cam Gears (6) OEM Lifters Timing Chain Tensioner Redtop Valve Cover - $35 PRICE DROP S13 Throttle Body with TPS - $40 OBO PRICE DROP Nismo Transmission Mount - $45 Circuit Sports Overflow Tank Anything else you may need I might have so just ask ![]() PM or Txt (954)822-Two Five Zero 7 for quickest response Parts Sold SplitFire Coilpacks - SOLD GT2871r .64a/r - SOLD Tomei Expreme Manifold - SOLD Tomei Rocker Arm Stoppers - SOLD Greddy Intake Manifold - SOLD Greddy Oil Filter Relocation Kit - SOLD Greddy Pulley Kit - SOLD Greddy Oil Pan - SOLD All lines for working A/C in an SOHC S13 - SOLD Circuit Sports Downpipe with bung added for AEM Wideband - SOLD 1 Piece aluminum drive shaft - S13 NON ABS - SOLD Z32 MAFS - SOLD Power Steering Pump - SOLD Alternater - SOLD APEXi Intake cone with 3" pipingpro.com GT2871r intake pipe - SOLD Cam Angle Sensor with Clear Cover - SOLD A/C Compressor & Bracket - SOLD Tomei 740cc Injectors in Stock Rail with SARD Fuel Rail Adapter - SOLD HKS 264/264 Step 2 Camshafts (less than 2k miles) slight wear on finish from oil starvation - SOLD SR20DET Cam Shaft Oilers (Bought new in April) newer design with larger holes from what I can see - SOLD Shortblock - SOLD B&M Short Shifter - SOLD ATI Racing Damper (May go with shortblock) - SOLD S14 Waterneck (Bought New) - SOLD SPEC STAGE 3 CLUTCH (515 FT-LBS TQ) - SOLD EXEDY LIGHTWEIGHT FLYWHEEL - SOLD Apex-i Power FC (L-Jetro) (REDTOP SR) w/commander - SOLD (8) OEM Rocker arms - SOLD (2) Lifters - SOLD BC Valve Springs + Ti Retainers - SOLD SR20det (Redtop) to 1989 SOHC Manual trans wire harness - SOLD Fat Type O2 Sensor (<1 mile!) - SOLD Starter - SOLD Greddy Oil filler Cap - SOLD APEXi Power FC (L-Jetro) S13 Redtop with Commander (fresh from APEXi with a new board) - SOLD TIAL 50mm BOV on Greddy Hotpipe with nipple for Wastegate signal on hotpipe - SOLD S14 Circuit Sport Turbo Lines - SOLD If anyone has bought anything from me and would like feedback shoot me a pm and Ill gladly submit feedback and hope you will do the same in return
You has PM
![]() Join Date: Mar 2011
On the High Pressure line that goes into the Power steering, was that custom done?
Check out my build! #/f/builds-builds-on...s13-build.html |
#11 | ||
100 Shipped
Replied Quote:
LMK! ![]()
Already sold
Added pic of hotpipe BOV with added nipple for wastegate/boost cont signal Also added Throttle body with TPS f/s
#17 |
Pulling engine tomorrow - ill send u them tomorrow
Thanks Sent pics to number lmk Short block and a bunch of other things sold - list updated
#23 |
Hey is that an aeromotive fpr and do you still have it for sale. Also do you still have the strut bar. thanks!
4 SALE intercooler mafs valvecover rep fn01rc http://tinyurl.com/jmaxzilvia |
