So I just finished rebuilding my ka24det, due to detonation damage in all cylinders. I start up the engine for the first time and it's running very strange exhaust manifold glowing red and backfires ect. Checked timing on distributor and it was a tooth off. After it was running great! Except now I'm having a problem with oil smoke (blue) after engine is warm. I have one of those bore scopes cameras so I decided to check out the piston tops. I found that all of them have small pools of what appears to be oil settling on the exhaust side. The spark plugs look good from what I can tell. I changed the valve seals and some of them were bad / floating on the valve stem. So I figured great this will be an easy fix. Nope still getting smoke. All the work done on the rebuild.
-head decked -valve job, seats, guides -valve lash ( cut tip of valve to correct spec) -tomie 1.2mm head gasket -arp studs -upgraded to oil relocation and cooler -retune on ecu -blow through maf -isr t25 / t28 turbo ( sitting for about a year new bnib) It's seems to blow blue smoke if I give it quick heavy throttle and if I let the engine idle for awhile it will blow out a decent size cloud. The bottom end was also built about a year ago Cp pistons eagle rods clevite bearings Also the compression test results are very high 205 cold in all cylinders and 215 warm. Before the rebuild it was 145/ 155 avg. But due to the oil in the cylinders I feel that it's giving inaccurate readings. Next step is leak down. Any suggestions or help would be greatly appreciated Thanks Again ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
![]() Join Date: Mar 2012
some possibles,
if you are using the same intercooler from the previous det death did you clean it out before reusing it, or if the hot pipe is oily inside suspect compressor side leaking oil into the housing/hotpipe I see it was bnib turbo but can happen |
![]() Join Date: Jul 2005
Oil raises compression ratio and causes detonation. You can see flakes/chunks of piston missing because its been running like shit for quite a while. Check intake manifold for oil; if there isn't any in there, it has to be coming through the head somehow.
#4 | |
Yeah that turbo has been on a shelf for the past year, I haven't checked the piping for oil yet but definitely will |
The 205 compression seemed too high. I was worried about running boost on top of that but the pistons are good I checked them before I put the head back on. No signs of pitting or pieces missing. The cylinder head took all the detonation damage from what I could tell
![]() Join Date: Nov 2016
Interested in this, I have the same problem on my stock ka, I get the same puff of smoke when I’m at idle for a while and when I give it throttle it comes shooting out. Thought it was just a clogged cat- but let us know any updates as you do further inspection
#9 | |
One more time for the people in the back.
What is that picture of? That is a compression tester, not a leak down tester... 90 PSI is not good. Is that after you cranked a few times then did you just let it sit? Because that is not how a leak down test is done. What compression pistons do you have? Look like 9:1, you shouldn't be seeing 210 on a compression test cold.
MRP Manufacturing |
#16 | |
It's a custom leak down I made from an old compression tester. The harbor freight one wasn't cutting it. just subtract from 100 psi. So 90 would be 10% leak down Last edited by Jrguzman; 03-29-2018 at 05:25 PM.. Reason: Adding more information |
#17 |
Are you filling it with 100 psi then waiting to see how much leaks?
MRP Manufacturing |
#22 |
Yeah I'm trying to figure out how that can be. I replaced all of them. The only thing I can think of and I might be way off here. The machine shop cut the top of the valve stem to set the valve lash and I know that the ka24de uses shims for this I believe. Maybe the valve is being pushed under the stem seal and it is causing the leak. But that's just a wild guess.
#23 |
AFC #1
![]() Join Date: Oct 2003
I would be more inclined to think that the seals are wrong, bad or were installed incorrectly. What brand are they?
#24 | |
But I replaced them with basic felpro seals from auto zone. They were the same for exhaust and intake. I also checked before I took the head to the machine shop again to see if the seals were still seated and they appeared to be ok. Maybe to much play between valve and valve guides? I'm stumped, just hoping I can get it figured out before I reassemble everything lol |
#26 |
If the head is all good,I'm struggling to think of why it's still getting oil in each cylinder
I will need to ponder this longer the turbo is the only suspect that could be feeding oil into the motor/all four pots or the intercooler or pipe work from the previous blow up? |
#27 | |
#28 |
so we have the head is good and turbo is good,
now we need what is allowing oil into each pot ?, if it was just one pot I would say suspect cracked head or an oil control ring but not all four failing the same way, and looks like equal amounts of oil in each pot I don't want to say swap the head or re-ring the pistons as not convinced that is the fix but we are running out of options,I'm leaning towards rings more than head might have to pull one piston out and look for tell tale signs it's the oil in each pot that's throwing me off |
#29 | |
But assuming the head is in order I have heard that some cases after a valve job the increase in vacuum can pull oil past the rings. But I don't feel like that is the case because of the pattern of oil that is on the pistons and leak down results that I got. |
| 240sx ka24det blue smoke |
