s14 2jz swap
Finnished the swap but the throttle cable is too long and I only get 75% throttle need some help please. Is there a bracket I have to use or I have to modify the cable or is there a different cable other than the s14 cable that I have to use. Thanx in advance,
![]() Join Date: May 2010
![]() Feedback Score: 21 reviews
: Tech2 Motorsports : Products : Custom Tech 2 Throttle Cable Bracket :
If that doesnt help, I would try asking here: #/f/engine-tech/3841...is-thread.html Would probably get more educated answers. |
![]() Join Date: Apr 2007
you have to cut and re-weld the throttle cable bracket.
these are the best pics i have of how mine is.
![]() Join Date: Dec 2008
Trader Rating: (79)
![]() Feedback Score: 79 reviews
I am going to run a RHD S13 throttle cable because its shorter, but still havnt configured a bracket but listen to Flicktitty he is the JZ guru here on Zilvia
My Build: The "Coupe De Ville" 1JZ Build!! |
Hmm i've never thought of that. Be careful though the SOHC KA throttle cable is too short, Hence why the DOHC one you have to "loop" before going to the bracket cause it's too long. i'm interested in hearing if this works.
#9 | |
Trader Rating: (79)
