#121 | |
![]() Join Date: Mar 2008
yup 2 step on aem s2 http://youtu.be/rScOarcbyRY |
#123 |
#124 |
![]() Join Date: Jan 2008
allows you to have the pedal floored but the motor will not pass its set RPM, also timing is taken away to build boost
MunkyW3rkz Racing |
#125 |
So only kind of "comfort" thing, that makes your life a bit easier?
As I said, I don't need boost off the line yet... |
#126 | |
![]() Join Date: Oct 2011
timing isn't just taken away, it is decreased into the negatives, somewhere between -5 and -10, to combust when the exhaust valve is open. Thats why you get all the fire along with anti-lag. 2 step is just a early limiter set within your ecu to shut off at a determined rpm or clutch pedal release. |
#127 |
![]() Join Date: Aug 2009
I try to launch on stock rev limiter but it doesn't built positive boost at all. I am thinking using rev limiter as cheap way for no lift shifting. I have rush anti lag but I am afraid to use it as I heard horror stories about it.
#128 | ||
i know that i am putting it in the simplist way possible so he understands it
MunkyW3rkz Racing |
#129 |
![]() Join Date: Feb 2007
i hope to get my sr s14 out the drag strip soon. i ran a 8.45 in the 1/8th the day i got it with my 26" slicks off my Z on it. and since then i replaced the clutch and raised the boost from 7 to 15 and fixed a bunch of other issues so im hoping for some 11.9-12.2s. but we will see.
i got a 1.74 60' on my 26" m&h dot slicks on a xtd clutch that was in the swap when i got it.
you, its whats for dinner. |
#131 |
lets jump start this back, Saturday I will be doing my first shake down passes
E85 6266 sr20det - YouTube
MunkyW3rkz Racing |
#132 |
Hey santos good luck saturday. Do you have line lock? It looks like nisssan have 2 line coming out from master cylinder. Most cars have only 1 line that teed into 2 for left and right. Is anybody make line lock for 2 in 2 out?
#135 | |
I have a Line lock just havent installed it yet thats coming within a month. one is for th efront and the other is rear so you only need to run from the front to th eline lick sileniod then from there to the brakes ![]()
MunkyW3rkz Racing |
#136 |
![]() Join Date: Apr 2003
Trader Rating: (33)
Great thread!
Question for you guys is what wheel/tire (other than those of you who have posted) setup are most of you guys running? I have a set of NA supra wheels which are 16 x 9 and I am not sure which tire to go with. I am thinking I will pick up some 26x11.5x16 for the rears and contemplating running 17" GTO spare wheels in the front with like a 17x4.5 tire. What are you guys using as a setup in the front? FYI, this is going into an S14 body. Q45 3.69 LSD, 300zx TT axle + Q45 axle, Z32 TT Hubs. |
#137 | |
unless you are a big brake front like me then theres no need for the 17" unless you want the look. I am running the 17" alumastars with the M&H Radial 185/55. I needed a spacer to clear my Brembos.
MunkyW3rkz Racing |
#140 |
#142 | |
#144 | |
and the other white 98 from TRC it has a 2JZ |
#146 |
Trader Rating: (33)
I have z32 iron calipers and z33 12.75 rotors up front. I looked at the Alumastar 17's that your running but I found a local junkyard that has 2 GTO's that both have the spare tires for cheap.
I was leaning more toward the MT tires but I am open for suggestions. Amberly very clean setup. |
#147 | |
MunkyW3rkz Racing |
#148 | |
S14 KA-T 240 auto 700+hp vs S14 KA-T 5 speed 700+hp - YouTube |
#149 |
I like the way this thread is going. It is about time there are more people on this forum that do more than drift their 240. Amberlys13 that is a sick setup, is that a borg warner s374? I am going to run a mazworx sr22 motor with a borg warner s366 and I am shooting for 700+whp on e85, and then see how much it can make on c16 race fuel.
Let's keep this thread alive.
Sr22 in the works |
