hub adapter?
i was wondering if i did do a aftermarket steering wheel with a quick release do i really need the hub adapter? i know the hub adapter is for safty (cause it can collapse) but i will be in a full harness and if it does the job right i shouldnt hit the steering wheel. the reason i am asking is because i do not have very much room for spacers (hub adapter + 50mm quick release). i have a full cage (my bucket seat can go so far back). i have long legs but a short torso. is there anything out there like this http://e30m3performance.com/installs...ub/qr-hub1.htm for the 240sx s13. or is there a way that i can connect just the quick release without the hub adapter? this may be a stupid question so thanks for the help if any.
![]() Join Date: Mar 2005
you could cut down the arms on the hub (on a momo hub) and shorten it. then, reweld the 6 bolt hub ring to the shortened arms. if you've got a hkb hub where it's solid, same thing, cut it down and reweld.
if that's too much work, just get a thinner quick release.
A SPEC PRODUCTS CORP AME Wheels, Advan, ARC, Gram Lights, Nardi, Personal, Recaro, Works Bell, Work Wheels, Volk Racing, 5Zigen, & more! 626.618.1100 x 103 / aim: aspectuan ![]() ![]() ![]() |
![]() Join Date: Jul 2002
![]() ![]() Feedback Score: 3 reviews
just get teh FET quick release it is only bout an inch or so high
I never knew you could do that with an eggplant |
