![]() Join Date: Oct 2009
https://ibb.co/44RhSZ1
$10k FIRM Engine/Performance: S13 SR20det Red Top (316 WHP on CA91) Only ran Mobil 1Full Synthetic 10w30 Rywire harness Modified valve cover with custom catch can and AN lines LS1 coilpacks AEM V1 PCM Gates Micro V Belts Mazworx timing Chain Tensioner S14 SR Water pump and modified neck for temp sensor Walbro 255lph Fuel Pump Chase Bays returnless fuel setup and AN lines AEM FPR Radium top feed rail ID 1050cc injectors TIAL vband Wastegate on OEM manifold (atmospheric dump) AEM MAP sensor AEM Boost control solenoid Greddy 2 Row Radiator AEM Digital Wideband gauge AEM water temp gauge Nismo Thermostat Custom SS Power Steering line. Similar to Chase Bays line. 7 layer S15 Exh. Manifold gasket Garret GT2871 .64 HKS 264/264 Step 1 Cams Earls SS Oil and Coolant lines TIAL BOV Greddy FMIC Custom 3? Downpipe with flex section Catco 3" high flow cat(gutted) ISR 3" blast pipes(loud) Circuit Sport Poly Exhaust Bushings DIF SS Fire Sleeved Clutch line 6 Puck Clutch PBM Magnetic drain plug ATP short shifter Suspension: Powered By Max Coilovers Powered By Max style drop knuckles(exact copy) Brand New FLCA's and extended 25mm + gusseted Brand New Maxima Moog Inner Tie Rods Just got an alignment 4/25/2020 SPL Version 1 Toe Rod's SPL Version 1 Traction Rod's SPL outer Tie Rod ends(bump steer correction) Kazama RUCA's Driven08 Eccentric Lockout Kit Nismo 2 way LSD(real quiet after the Ford friction modifier) Villains modified axle stubs for Z33 axles Circuit Sport Tension Rods Johnny Fraz Tension Rod Brace(Like Nismo Brace) Energy Suspension Front Sway bar bushings/endlinks Energy Suspension rack & pinion bushings Z32 Rear 5 Lug Hubs Attain 5 Lug Front hubs with extended ARP studs and legit open end nuts Brakes: Z32 30mm Front Calipers w/ss lines & slotted rotors Z32 Rear Brakes with working Ebrake w/ ss lines & slotted rotors Z32 Rear Ebrake Assembly w/ powdercoated black backing plates Project Mu Ebrake shoes *Brand New Z32 1? BMC *Brand New Ebrake Cables Driven08 Z32 2+2 Ebrake cable bracket Wheels/Tires: Advan RGII Front: 18x9.0 +22 w/ 7mm Powered By Max Spacer(effective +15 offset) Rear: 18x10.0 +15 Exterior: Mercedes Black Single Stage Paint Kouki OEM Bumper Kouki OEM Turn Signals Kouki OEM Position Lights Kouki OEM Extensions Kouki OEM Extension Brackets Kouki OEM Sideskirts Kouki OEM Valences Kouki FPR Center Valence Kouki FPR OEM Style Spoiler Driven08 Kouki FPR OEM Style Lip (super flexible and strong) Kouki OEM Tail lights Raybrig H4 Housing Headlights 6k HID?s M3 Clear Sidemarkers w/ leds?s Interior: Black Dash Safety 21 6 Point Cage Nardi Deep Corn 350mm NRG Short Hub NRG QR Bride Zeta III w/ Gradation Bride FG Sidemount rails S14 Passenger seat Dyed black rear seats Black wrapped glove box Full Interior S14 Manuel Seat Belts DOHC Cluster w/ SR RPM Newish Turn Signal and Wiper Stalk Leather Shift boot More pics coming soon
As long as you're not a ham-fisted retard there shouldn't be a problem. |
| kouki 180sx, s13, type-x |
