Old 07-11-2009, 08:16 AM   #1
warauto
warauto is on the path to ruinwarauto is on the path to ruin
s14 radiator hose leaking
I have a redtop Sr in an S14 i modified the stock KA Radiator to work with
my motor for monetary issues. It recently started leaking from the top of the radiator. I got a used Sr rad and was planning to swap out. But this morning when i went to check the fluids coolant was leaking from the top part of the house towards the engine. The first thing i thought was it the headgasket.....what do yout guys think.....
warauto is offline   Reply With Quote
Old 07-11-2009, 10:13 AM   #2
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
why would you think its the HG? if the HG was leaking it would burn coolant or mix coolant and oil, not leak out of the water outlet. the hose that you have on there is most likely leaking.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 07-11-2009, 03:49 PM   #3
warauto
o ok, well i changed the radiator to the sr one and customed a hose. I will see it it stops leaking now. Thanks
Is there any hose that can be used with the Sr radiator that i can get from like discount auto or any other auto parts store?
Old 07-12-2009, 12:45 AM   #4
zenki.life
zenki.life's Avatar
zenki.life is an unknown quantity at this point
Send a message via AIM to zenki.life
yes there is a hose........i believe it is called a SR RADIATOR HOSE!!!!!!!!!!(AKA NON "MODIFIED" KA HOSE!!!!!!!!!)
Originally Posted by super240s14 View Post
man you all are ass holes...... and that is rude to talk like that on zilvia im reporting all you...... ZILVIA ADMINISTRATION PLEASE BANNED ALL THREE OF THESE DUDES
^^another person learns the perils of "stupid posting" on zilvia, too bad none will care.
zenki.life is offline   Reply With Quote
