SR 0 Compression
Hey guys i apologize if this is a redundant question but ive got mixed answers through research.
Im doing a complete SR rebuild so i bought a motor with a blown HG and it was tested showing 0 compression. My question is, is it possible to have no compression with just a blown HG or is there other factors involved.(valves are not bent, no holes in pistons). Obviously the machine shop will determine if i will need a new head or block i was just curious because i have heard even with a blown HG there should still be SOME compression. |
![]() Join Date: Jun 2007
I would 'think' that there could theoretically be zero compression at whatever cyl the HG let go at... but I'm anxious to hear what other, more competent people have to say.
Hopefully you won't need a new block or head; just some machine work.
![]() Join Date: Mar 2012
The HG can blow out between the cylinders and give zero comp readings
but it looks intact in the picture tbh But I would be more concerned about what looks like detonation damage to the piston crowns, could be ring land area damage/collapse causing the zero comp reading |
Yeah the motor had overheated. It just amused me that the head gasket had no visible imperfection . I will be going with forged pistons and nearly everything new , I was just worried about the block and head. I guess machine shop will tell the story. I've also heard that the Hg on the sr is like a "fuse " for the motor and it'll let go in order to prevent any further damage.
Lots of people get upgraded HG's (and there is absolutely nothing wrong with that)... but then crank up the boost; never realizing that adding boost and not blowing stuff up requires tuning ![]()
Yeah so fingers crossed that the machine shop will be able to take care of it, to my naked untrained eyes everything looks fine but we will see. I'm shooting for around 350 to the wheels on pump for a grip set up.
Check the exhaust valves for cracks running through the seat to outer edge
,and cracks spreading out from the spark plug hole is another thing I've seen on SR's, either will loose compression might be worth finding another head from a known not boiled over engine for future reliability on track |
No overheating would cause a timing issue I was thinking maybe u had the car apart at one point and possibly could've adjusted the timing wrong, I did that n I lost compression in cylinders 3 and 4 I thought I bent valves be jus to be safe I readjusted the timing and the compression came right back
W.I.D.S.I. O
Yah those valves dont look so hot, or I shuld say lookes like they have been very hot. Its really hard to say I dont know what your plan is but. I would clean the piston tops and wipe down the cylinder walls and inspect the hatch and walls in general. if all is well maybe you can get away with a re-ring, rod bearings, and complete head service. Maybe pick up a used head for spare parts or to service. I just had to do the similar to a beat RB20 I got
