300ZX E-brake Conversion for S13 S14 / 5 Lug Hubs
I'm located in Rancho Cucamonga/Fontana 91730 Area code, I can ship if needed.
All parts were working when removed but as is. No trades needed, Thanks for looking! 300ZX Emergency Brake Conversion If you are running rear z brakes you need this. Includes all hardware and anchor bolts, springs, nuts, etc. This will fit both tabbed and non-tabbed hubs Pads have good meat on them, comes with 2+2 cables for S13 or 3ft of cut cable for splice method found here: http://importnut.net/300zxbrakeswap-ebrake.htm 300ZX Ebrake Conversion w/cut cables - $165 300ZX Ebrake Conversion w/2+2 cables - $195 ![]() ![]() 300ZX Tabbed Rear 5 Lug Hubs $100 S13/S14 Bolt on rear 5 Lug, bearings are tight ready to use. Came off driving car. ![]() ![]() Last edited by surly; 01-26-2018 at 01:26 AM.. |
