Old 03-09-2015, 11:57 PM   #151
shoguner
shoguner is an unknown quantity at this point
Originally Posted by JZ78 View Post
Nice build you got going there! I'm now changing my plans, I'm going to do the uz swap now in the near future! Keep it up man.
sent from my mind
Thank man!
1uz's are fun.
1uz build. Wiring on Page 2
Click
shoguner is offline   Reply With Quote
Old 03-10-2015, 12:51 PM   #152
Clutch Dog
Clutch Dog's Avatar
Clutch Dog is an unknown quantity at this point
Send a message via AIM to Clutch Dog
Hey shoguner, im back from being underway for so long. I have my 1uz out on an engine hoist right now.
how much material did you have to grind from the trans bellhousing
what do all the connections to the intake manifold go to
i saw you blocked off your ISC so how does the car idle?
and got any pics of how you ran your fuel lines? power steering lines and brake booster lines?
Mad Moody Science LLC In house is the best way.
Clutch Dog is offline   Reply With Quote
Old 03-10-2015, 03:46 PM   #153
shoguner
How ever thick your adapter plate is.
I am not sure what you mean?
Ya i blocked off my iacv, it went bad anyway. Idles great, just adjust your throttle body so it idles at a decent rpm, you will have to let it warm up before it will do any thing. You might have to keep the throttle open for a few secs upon start up.
i will get some tonight. I just grabbed two of the banjo fittings on the back of the intake manifold and put them on the fuel rail, then i ran the pump to one side and the FPR on the other side at 35 or so PSI.
power steering line is a custom hose from summit, check this thread out, it is in there somewhere.
brake booster goes to the rear of the intake.
Click
Old 03-10-2015, 10:04 PM   #154
shoguner
Holy shit guys!!!
Only have to break those rings in and get the hood/fenders bolted down!!!
I might aucutally make the event on saturday!
Everything is all hooked up.
Cranked it with out spark plugs and the fuel pump turned off to prime the oil.
She climbed up to 55psi and fell and held at 40psi.
I think everything is good to go.
I am useing 6qts of rotella 15-40w diesel oil, plus a bottle of lucas zinc adder. As i have read, this is a good way to do it.
I will have a video up tomorrow!
Click
Old 03-11-2015, 10:53 PM   #155
Clutch Dog
Clutch Dog's Avatar
Thanks I figured out the idle as well as the fuel and the other lines. im just waiting on the summit parts..
Fries had them on his page of what parts to get the power steering connected. Ill have to re'look at the idle thing a bit. I have an aftermarket ecu so i could run the stock ISC valve.
Old 03-11-2015, 11:50 PM   #156
shoguner
I would get rid of it, honestly. It's not worth the headache.
Click
Old 03-11-2015, 11:58 PM   #157
shoguner
Well... the engine....
IS ALIVE!!!!
Video is uploading.
Will be getting the hood and fenders on tomorrow, then onto the trailer.
Click
Old 03-18-2015, 08:31 AM   #158
shoguner
http://www.youtube.com/watch?v=p4QBlTqrTto
So....
Last Tuesday it had 40psi of oil pressure while cranking with no plugs to prime the engine.
Wednesday, start it, it has 0 oil pressure (as the gauge says).
Take off the sensor, oil pours out while cranking. (Must have oil pressure, right? See video.)
http://www.youtube.com/watch?v=SjX6yAmomwM
Let it idle for 30 mins to seat the rings.
Drain oil, put 6 qts and new filter back in. Only got about 5 or so quarts out. So, it had to be pumping oil somewhere.
Thursday buy new gauge and sensor.
0 psi still, take off sensor, no oil squirts out.
So I took the filter off, and then filled it up about half way. Cranked it, oil pumped out. So take filter off. So, i think air must be pumping?
I'm super confused.
I'll be taking off the oil pan this weekend or sooner to see if the oil pick up tube has somthing wrong with it.
Click
Old 03-26-2015, 11:09 AM   #159
shoguner
So,
fixed the oil issue.
It was the pressure relief.
Also.
Whoops.
Click
Old 03-26-2015, 11:13 AM   #160
TheRealSy90
TheRealSy90's Avatar
Well that engine didn't last long haha.
Such a good signature.
Old 03-27-2015, 07:21 AM   #161
shoguner
It turned into a 91 miata. haha.
Click
Old 03-30-2015, 12:51 AM   #162
Gr1mey_Norm
Gr1mey_Norm's Avatar
Gr1mey_Norm is a well-known jackass
Turned into a Miata...now thats some fab work for you!!
Gr1mey_Norm is offline   Reply With Quote
Old 04-09-2017, 06:30 PM   #163
914Slide
914Slide's Avatar
914Slide can only hope to improve
and thats it just sold it ?
914Slide is offline   Reply With Quote
Old 04-10-2017, 12:00 AM   #164
Malik
Malik's Avatar
so this build thread is done.
Old 04-21-2017, 10:57 AM   #165
shoguner
Traded the engine swap for a mitata. realized how dumb miatas are. Sold miata. Bought M3. drove m3 for a year. M3 broke. Bough 2014 q50. Lived life for a bit. Then picked up e36 and am now putting a 5.0 in it.
Click
Old 06-01-2017, 11:14 PM   #166
914Slide
914Slide's Avatar
Originally Posted by shoguner View Post
Yup! hahaha
sweet alignment tool now
