Old 08-17-2010, 11:25 AM   #1
ANVIL
ANVIL's Avatar
ANVIL can only hope to improve
stock 6 bolt -> 5 bolt vlsd help
So I have a stock open diff in my 89 that has 6bolt axles. I bought a 5 bolt vlsd and it came with the whole pumpkin and the inner 5 bolt axles. What can I do to this this to work aside from buying 5 bolt outer axles? Is it possible?
ANVIL is offline   Reply With Quote
Old 08-17-2010, 11:33 AM   #2
Sam_Well.13
Sam_Well.13 is an unknown quantity at this point
its better to buy the axles, unless you want to take apart your pumpkin to swap out the 5 bolt to the 6 bolt.
Sam_Well.13 is offline   Reply With Quote
Old 08-17-2010, 11:39 AM   #3
ANVIL
ANVIL's Avatar
I don't mind doing that to save time and money. What's involved exactly?
Old 08-17-2010, 11:41 AM   #4
uraznfriend
uraznfriend's Avatar
uraznfriend is an unknown quantity at this point
is it possible to take the half shafts out of a vlsd and swap to the 6bolt half shafts?
uraznfriend is offline   Reply With Quote
Old 08-17-2010, 11:54 AM   #5
niteridaz503
niteridaz503's Avatar
niteridaz503 is an unknown quantity at this point
You can swap out the half shafts on the VLSD from 5 bolt to 6 bolt ones if they match up. Only way to tell is by taking them out (beat mine out with a hammer & pry bar) other than that i believe some are interchangeable form 5 to 6 bolt IIRC don't quote me on that tho.
Also make sure if you do take them out not to mix them up because each half shaft is a different length so keep them separate it will help you alot when you put it back together
Originally Posted by yetijeff View Post
Hes higher than giraffe pussy lolz
niteridaz503 is offline   Reply With Quote
Old 08-17-2010, 11:55 AM   #6
Souljahzs13
Souljahzs13's Avatar
Trader Rating: (66)
Souljahzs13 is an unknown quantity at this point
Feedback Score: 66 reviews
To save time and money, it will be cheaper and less time consuming to just get j30 axles. You can not convert a 5 bolt vlsd into a 6 bolt, the spline lines are different and can not be swapped
Souljahzs13 is offline   Reply With Quote
Old 08-17-2010, 11:57 AM   #7
Sam_Well.13
i jst saw that. but you beat me to it..
yeah. 5 bolts axle arent that expensive if you get lucky around here.
Old 08-17-2010, 12:06 PM   #8
ANVIL
ANVIL's Avatar
I'm pretty sure I won't find any axles here. There's only like 20 240s in the state. Man so I HAVE to get new axles? That sucks the guy I bought it from said it would work. Lame
Old 08-17-2010, 12:24 PM   #9
ANVIL
ANVIL's Avatar
How much are used 5 bolt axles normally?
Old 08-17-2010, 12:46 PM   #10
Souljahzs13
Trader Rating: (66)
about $80-100 for some used pre 94 infinity j30 axles
Old 08-17-2010, 01:41 PM   #11
ANVIL
ANVIL's Avatar
What othe axles will work? What trim of 240 did 5 bolt Axles come from?
Old 08-17-2010, 03:49 PM   #12
ANVIL
ANVIL's Avatar
91 q45 axles work?
Btw WTB axles that will work pm me
