Which brake booster should I go with? Z32 or S14? (F+R z32 Brakes)
I have Z32 brakes in the front and rear. I also picked up a 1" z32 BMC. Now I'm trying to figure out which brake booster to go with. Should I go with a Z32 brake booster or an S14 non abs brake booster?
FYI: I'm running a KA24DE but may eventually swap in an SR20 if it makes any difference for clearance? |
What motor are you running? I'm running a stock KA24de but may eventually swap in an SR20DET. Also how is the pedal feel for you? Is it squishy or firm?
| brake booster, conversion, z32 |
