Old 10-23-2018, 08:51 PM   #1
Darfin
Darfin is an unknown quantity at this point
KA KA24DE dies when accelerating
Since i've gotten my bucket, i've gotten it to run, but not run amazing.
In the past (like 1 month of actually being able to safely be driven) it would drive fine,but slowly developed a problem where it would not go above like 4k RPM. Then to 3.5k, then 2.5k until i switched out the fuel pump and filter.
That fixed that (or so I thought) and now it seems that any time i gas it (or even attempt to normally accelerate) it fuel cuts, then dies. As if the gas pedal does nothing but makes the exhaust pop a little more as it cruises down to the engine's stopping. It frequently takes a bit of cranking and gas to get the engine to restart.
The issue is quite dire, as i can't go 30 seconds without it happening. Did I buy a bad fuel pump?
Things 'done' to the car that may be related:
-New injectors
-new fuel soft lines (high pressure)
-'cleaned' gas tank when i got the car (was rusty in side with nasty fuel, cleaned it as best i could by pulling it and scrubbing the inside and using a few cleaners to soak in it prior to reinstallation)
-new spark plugs
-recent egr delete
Darfin is offline   Reply With Quote
Old 10-24-2018, 01:38 AM   #2
1on1
1on1's Avatar
Possibly have a bad maf.
instagram
Old 10-24-2018, 09:08 AM   #3
jedi03
sounds like timing jumped to me...
Old 10-24-2018, 01:03 PM   #4
Darfin
Thanks, i'll check both of those things.
Old 10-26-2018, 07:34 PM   #5
Darfin
I checked both the timing and the MAF, both are good. I used a different MAF just to make sure things were in order, and no change. I even checked to see if the fuel line was clogged, to no avail.
I suppose next step is getting another fuel pump and praying it works?
Old 10-27-2018, 06:22 PM   #6
1on1
1on1's Avatar
Hmm weird. I had an issue where my positive battery wire (relocated into trunk; s14) was corroded over the years. I swapped in a new one for both connections and my car runs flawlessly.
Maybe double check the engine harness/charging harness to see if there are any open wires or corrosion.
instagram
dies out, fuel cut, fuel delivery, ka24de
