#15093 | |
![]() Join Date: Nov 2007
for the sake of keeping this a fitment thread. 18x9 +12 18x10 -1 (25 mil spacer) 30mm front fender and 30mm rear pinched to about 60mm. gramlight 57 maximum pro ti |
#15096 | |
REALLY...YOU DIDN'T FUCKING SEARCH! 10 seconds. "18x12 245" who fits 18x12 in back on stock fender - Club Lexus Forums p.s. on the gold car. probably the most famous s13's in the U.S. |
#15099 |
page 47 of this thread....
F: 18x9.5 -10 225/40R18 federal -4 degrees camber R: 18x12 -14 245/40R18 federal -1.5 degrees camber The frontfenders are resting on the tires and it drift just fine like that. front and rear fenders are Bmagic 30mm front and 50mm rear bowed out. |
#15100 |
shit, i even saw that pic and assumed it was still the 45's
thanks man, its pretty much exactly the same setup im getting only on on 14, im off to look up how to 'bow' overfenders now thanks again! |
#15101 | |
![]() Join Date: Dec 2003
HEY YOU...... GUY
Nobody cares and your annoying as fuck. That is all. I swear to god we are moving from spoon fed to the age of suppository info. Quote:
S.P.P.S. Member #00**CoUpe LOve** Member #00 |
#15105 |
Weight is a HUGE factor. That is why race wheels are so expensive. Rotational mass is multiplied by 3. So lets say you have 20lb wheels. You Change to a set of 25lb wheels. You effectively gain 15lbs a corner. That is a total of 60lbs overall on the car. It is also said that for every 30lbs you add to a car, it will be a 10th of a second slower. So 2/10th slower over just 5lbs. So your 20lb TE37's compared to your 40lb steelies is around a second slower then the TE.
iTrack Motorsports GTA Street RWD Miata #5 |
#15106 |
Thank you kind sir.
18x10 -1 seems a bit mild for 60mm (effective) overs. Did you not want to run much negative camber or something? I'm planning on 18x10 -7 on some 30mm's that are in the mail. I too, don't want to run a ridiculous amount of neg camber. Is this realistic? You're throwing me off with the 60's lol. |
#15114 |
MEH its coming together but still looks like poop!
![]() 17x10.5-3 225/45(needs a smaller front tire ugh) 17x10.5+27 225/45
OKSTANCE.COM FANBOY HATE MAGNET |
#15119 | |
![]() Join Date: Mar 2007
just a though... wtf. no.
