Old 08-01-2013, 02:35 AM   #1
Cronus577
Cronus577's Avatar
Cronus577 is an unknown quantity at this point
Electrical fan wiring problem
Hey guys, I just got my first 240 over the weekend and the guy before me wired 3 fans into 1 switch and it's getting extremely hot and im afraid it's going to burn out soon. I was going to run 2 fans on 1 relay and the third on another. Since this is my first wiring gig I was curious if anybody could help me. I drew up how I THINK it should be, but correct me if i'm wrong, I don't want to screw up. I'm running 12 gauge wire on 30a switches.
Cronus577 is offline   Reply With Quote
Old 08-01-2013, 02:47 AM   #2
Rich260z
Rich260z is an unknown quantity at this point
You need power to the switches, but yeah the looks like the right idea. I also think the relays are grounded which I can't see either.
Rich260z is offline   Reply With Quote
Old 08-01-2013, 03:04 AM   #3
Cronus577
Cronus577's Avatar
I keep seeing people interchange 85 and 86 as grounds, As far as what i've been able to read and what you've told me it should look a little bit more like this. Should I put fuses going to the switches as well? Sorry for the crude MSpaint getup
Old 08-01-2013, 10:34 AM   #4
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Why do you need 3 fans?
CLICK HERE!!!
Old 08-01-2013, 10:51 AM   #5
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
You only need 2 fans and 2 relays. Make sure the source power wire is 12 AWG all the way through, those cheap eBay sockets that plug into bosch style relays are usually only 16 or 18 AWG so you will have issues. Your grounds also need to be 12 AWG or bigger. Since you are tapping directly from battery you will need 30A fuses for each fan relay power source, about 1 foot from the battery.
Old 08-01-2013, 01:49 PM   #6
Cronus577
Cronus577's Avatar
Sweet,when I got the car it came with 3,ill probably take the push fan off and do just the 2 pulling, I have 12 awg wire and 2 30a fuses, 30a switches, and some 30a relays. I'm just trying to get an idea of how to wire this, if anyone can draw sonething out
Old 08-01-2013, 08:49 PM   #7
KiLLeR2001
Trader Rating: (46)
This is as easy as it gets...
Old 08-01-2013, 09:38 PM   #8
Cronus577
Cronus577's Avatar
Thank you, that's exactly what I needed!
Old 08-02-2013, 12:08 PM   #9
cotbu
cotbu's Avatar
I don't agree with that diagram! A relay wired like that makes little sense. Will it work???? isn't my question. Why use a relay for that? Is the question.
Old 08-02-2013, 12:13 PM   #10
KiLLeR2001
Trader Rating: (46)
Since he has 30A switches he doesn't have to use relays. But me personally, I like to run my accessories (like cooling fans) on relays.
edit:
If you don't want to use relays, and you have a switch that is rated for 30A...
Old 08-02-2013, 12:24 PM   #11
cotbu
cotbu's Avatar
I know, me too.
edit:
That new diagram would be more simple for anyone that needed to wire up fans, that didn't want or understand relays.
