![]() Join Date: Apr 2004
FS Z32 MAF & Other Misc stuff.
Seems like people have money to buy stuff now?
![]() CoolSat 8100HD for you FTA guys who know what this is. Barely used. ![]() ![]() Stock S13 Rear Suspension Arms -- Bushings still good! Stock S13 Front/Rear Brake setup -- Calipers, rotors, pads, e-brake cables Stock S13 BMC -- Has about 10k miles on it, was bought new. Stock S13 Front/Rear 4 lug hubs -- Use or cannibalize for bearings. Stock S13 Steering Wheel -- No rips/fades S13 Sun Visors Stock R33 RB25DET Clutch -- I think it's stock... doesn't slip. Stock R33 RB25DET S1 ECU -- Worked when it was pulled out Stock R33 RB25DET Slave Cylinder -- No leaks. Stock R33 RB25DET Injectors -- 370cc Side Feeds, can use with SR Stock R33 RB25DET Water Pump -- 40k miles, impellers intact, spins freely Stock R33 RB25DET Rubber Intake Tube Stock R33 RB25DET FPR RB25DET Divorced Turbo Elbow -- 6 bolt housing, came with HKS turbo K&N FIPK for KA24(D)E -- Filter & MAF Adapter Z32 Rear Aluminum Uprights Generic Catch Can/Reservoir ![]() ![]() ![]() Stock S13 Hatch Tails -- No cracks, but no harness/bulbs either Stock S13 Hatch Lower Tail Garnish -- Red, no dings Stock S13 Hatch Rear Seatbelts Stock S13 Lower Rubber Shift Boot Stock S13 Center Garnish -- Missing 2 clips, no cracks KA24E Auto ECU -- No Speed Governor/Fuel Cut ***Z32 Maf w/ pigtail for $100 shipped*** Universal Group A Vent -- Fiberglass, new, never mounted Universal Aluminum 30 Row Oil Cooler -- No leaks, -10 AN Fittings Universal Power Steering Cooler -- No leaks, barb fittings CATCO 3" High Flow Cat -- Flanged for S13 Pioneer 6x9 Speakers -- Pair of 5-way, surrounds intact, 80w RMS ![]() PRC Racing Radiator -- New 2 row w/ integrated oil cooler. Approx 18x26. Post or PM me your offers! |
